Results 1 to 15 of 17
    Dec 2012
    Default Cccam setup on Blackhole image for Vu+ Duo
    Hi there,
    I am new and need your help to walk me through the process step by step. I have a Vu+ Duo and just downloaded the black hole image 1.7.8 Light (No HbbTv). I need to setup the CCcam but no sucess yet. Could anyone please explain to me what other bits I need and how to install them to get my Cccam.config running again. also any tips will help as I do not know much about this stuff
    many thanks
    Cheers
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    Quote Originally Posted by kensington View Post
    Hi there,
    many thanks
    Cheers
    look here at post 2
    http://www.digital-kaos.co.uk/forums...-cccam-287037/
    Please Read Carefully!
    No Sky UK NDS Videoguard Hacking Discussions.
    Viewing Pay TV without a valid subscription is illegal
    the files available are kept for experimental & educational purpose only
    original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
    V.I.P. Member mdt's Avatar
    Feb 2009
    bolton, north-west. uk
    Hi there,
    Cheers
    B.H.1.7.9 is out for your duo now... regards mdt
    DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
    Dec 2012
    I have already did what was discussed in the previous posts with no success. could u please list all the bits that I need to get my cccam working on blackhole. As I said I installed 3 type of cccam and activate them and still no success
    May 2008
    Did you add YOUR sea lion details to the config file?
    Feb 2012
    Or just install tspanel and download from the server.
    Never had a problem yet.
    Dec 2012
    What is sea lion details and how to add them? where to install Tspanel to? I only added 3 type of Cccam2.3.0, 2.2.1, and 2.14. I could find them and activate erach one by pressing the blue button. I added ccam.config as it is when I used it with previous team official image. so smeting missing? do I need to put VTI feed file opkg folder as I did with previous image? I got feed up this morning with this and tried VTI image and it worked but I still want to try blackhole image as I find the quality of the picture a lot better. I know you may be bored with this but pz remember any detailed explanation will be much appreciated than just refering me to another treat. Please also give me the link to any files I need to add.
    Much appreciated
    Dec 2012
    Please list all the bits of the process to get my cccam config to work on vu+duo with Blackhole image. so far I could add ccam2.2.1 and activate it. and put my cccam.confif in the ext folder.
    Feb 2012
    Do you have a sea lion in the .cfg file? You need a line in cccam for the channels to open.
    Dec 2012
    yes I have the lines and I already been using it with previous image and also working on VTI image. but I could not get it working with Blackhole image. I may have missed something
    V.I.P. Member dell_xps's Avatar
    Having same problem here m8, press blue button select one, reboot, then nothing ?
    Ok got it working after selecting restart, tried restart gui etc, must have to be select Restart m8.
    Dec 2012
    I can see the cccam 2.2.0, or 2.1.4 and I can activate and checked all of them but yet won't work. Do I need other files to add to the image in order to work with cccam.config to work. I used my previous cccam.config file that was working with VTI image. should not I need to add VTfeed file to opkg folder? is there any bits that I need to add? I did not unzip the cccam 2.2.0 and others when I added them to temp file. I could see them and it showes activited after pressing the blue button. do I need to change the configuration of my cccamconfig with lignes?
    Many thanks. Please list all the bits of the process and any links to the files needed
  13. #13
    File is just called CCcam.cfg m8, has to be that ok !!
  14. #14
    Feb 2012
    Make a cfg file in notepad. Enter cline, save as CCcam.cfg and click save. Choose save as all files and ftp to etc
  15. #15
    Nov 2008
    north west uk
    you dont need other files if you loaded the cccams as i posted
    the cccam cfg file will be in the etc folder then just need to add
    the info you got from the server by opening the dcc>click>ftp
    then double left click the etc folder in the left panel on the dcc
    to open it then scroll down and find cccam cfg then you right click it
    and on the small panel that opens left click edit to open it, then scroll
    to the bottom of the list and copy and paste your info in this file and
    then at top left of the file click the save and exit icon and then say yes on the small panel that opens,close the dcc and with your remote press blue set the
    cam version you want to use and click ok on it to start the cam jour chns should now open
