Ok So i have managed to do some work on my own car , been up to my eyes all year, keeping customers happy . here goes
Have Mk3 Golf which i have fitted a 1.8t engine in AUQ all fitted in the car perfectly have kept it all original with engine loom and wired up it now starts and cuts out and i keep get these codes
Saturday,22,December,2012,17:43:09:46862
VCDS Version: Release 10.6.0
Address 01: Engine Labels: 06A-906-032-AJQ.lbl
Control Module Part Number: 06A 906 032 HN
Component and/or Version: 1.8L R4/5VT 0001
Software Coding: 11500
Work Shop Code: WSC 00142
Additional Info: TMBBL41U012444204 SKZ7Z0Y0626782
VCID: 71E2D79A57F30C94
16 Faults Found
17931 - Crash Signal from Airbag Controller: Implausible Signal
P1523 - 35-00 - -
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-00 - -
17951 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Small
P1543 - 35-00 - -
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
P1172 - 35-00 - -
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-00 - -
17987 - Throttle Actuator (J338): Adaptation Not Started
P1579 - 35-00 - -
16621 - Manifold Pressure / Boost Sensor (G31): Signal too Low
P0237 - 35-00 - -
16727 - Camshaft Position Sensor (G40): Signal too High
P0343 - 35-00 - -
17834 - EVAP Purge Valve (N80): Open Circuit
P1426 - 35-00 - -
17956 - Boost Pressure Regulation Valve (N75): Open Circuit
P1548 - 35-00 - -
17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
P1118 - 35-00 - -
17841 - Secondary Air Pump Relay (J299): Open Circuit
P1433 - 35-00 - -
17939 - Camshaft Timing Adjustment: Open Circuit
P1531 - 35-00 - -
17695 - Boost Pressure Control Valve (N249): Open Circuit
P1287 - 35-00 - -
17949 - Fuel Pump Relay (J17): Open Circuit
P1541 - 35-10 - - - Intermittent
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-00 - -
I have put a file in the Ecu to bypass the immo not sure if that is where my fault lies ecu is 0261 207 440 Bosch ME7.5 original file eeprom 95040 attached
Can anybody shed some light thanks
