Results 1 to 15 of 18
    V.I.P. Member gizmo.1484's Avatar
    Apr 2008
    WestYorkshire
    Default Problem with seat alhambra 1.9tdi
    I was driving it the other day and it started spluttering and then just cut out. Then the coil light on the dash started flashing. I had just put some redex in the tank when I filled up, so I was thinking maybe the fuel filter was blocked. So I changed the fuel filter, then filled the fuel filter with diesel to prime it. Then the vehicle started up but then cut out after all the fuel from the filter had been used..
    So what could be the problem?? It seams like there is no fuel coming from the tank.
    Sep 2008
    can you pump fuel up,if you only get air would suggest an air leak/fracture in not supplying fuel,strainer in tank blocked due to bad fuel.
    Apr 2008
    WestYorkshire
    Checked and cleaned fuel sender in tank, how does the sender work as it is electronic. Could this be the problem? How can i check to see if this is working.
    genius76's Avatar
    Dec 2012
    Lowestoft
    1996?2010 !?
    1.9L I4 66 kW (90 PS) TDI
    1.9L I4 81 kW (110 PS) TDI
    1.9L I4 85 kW (116 PS) TDI
    1.9L I4 96 kW (131 PS) TDI
    1.9L I4 110 kW (150 PS) TDI !?
    Meat-Head's Avatar
    Quote Originally Posted by gizmo.1484 View Post
    WHOA - the sender ONLY does the fuel gauge.
    When you had it out, was there a funky pump?
    For a VW to flash glow worm light is is a 'serious' problem.
    plug a computer in next.
    genius76's Avatar
    Dec 2012
    Lowestoft
    This is not a serious problem just replace the BOSCH pump
    Sep 2008
    funky pump or relay,or is that only in the petrol version.
    Nov 2010
    First connect a computer and and read dtc
    What year of car? Bosch pump or PPD?
    If car after 2000 y you must check fuel pressure after filter -0.8-0.9 bar If pressure ok -you have problem with pumpe duse
    better to buy 1 used and replace one after other
    If car before 2000 y -better to buy used bosch pump and replace
    Apr 2008
    WestYorkshire
    Sorry year is 2002..
    It started when I filled the fuel filter with diesel but cut out after it was used, so does that not mean the fuel pump is working as it needs to pump it to the injectors?
    Meat-Head's Avatar
    Repeat experiment. Do not rev engine. If that fails represt experiment rev nuts off it
    Apr 2008
    WestYorkshire
    Right checked the fuel pump and sender in the fuel tank with a meter and there is no currant going to the fuel pump, so does that mean the relay as gone??
    Meat-Head's Avatar
    High chance of it go stalk member Smokey08 THINK he knows the relay off top of head try realy "109"
    full of dry joints
  13. #13
    smokey08's Avatar
    Essex, UK
    Fuel pump relay is 53.
  14. #14
    genius76's Avatar
    Dec 2012
    Lowestoft
    Checking fuel pump if relay is ok
  15. #15
    Meat-Head's Avatar
    Quote Originally Posted by smokey08 View Post
    i was talking about you, not to you.
    Susspose 53 is a good number - you only want the thing to you do run run
