Results 1 to 15 of 16
    Default Ford 6000 radio locked 13
    Please I need help, Ford puma shows locked 13, I've tried everything taking car battery out for 12hrs, leaving ignition for along time etc. I have the code but it won't accept.
    needed resetting now m8
    it won't unlock no more
    How do I reset it?
    genius76's Avatar
    Dec 2012
    Lowestoft
    1. Drivers door open - leave open.
    2. Ign. ON. - Use RED key only.
    3. Radio ON.
    4. Press and hold presets 1, 3 and 6.
    5. Ign. OFF then back ON within 1 second.
    6. Release presets 1, 3 and 6.
    7. Radio OFF.
    8. Ign. OFF.
    Repeat the above the same number of times that is showing on the display when jou started. i.e: 10 or 13.
    Quote Originally Posted by genius76 View Post
    3. Radio ON.
    7. Radio OFF.
    8. Ign. OFF.
    Tried that a couple of times but no success. Just to be sure, which one is the RED key? I've used all three keys I've got.
    genius76's Avatar
    Dec 2012
    Lowestoft
    Ford 3000, 4000, 5000, 6000.
    The official line is - straight from October update of FORD TIS.
    3. Radio ON.
    7. Radio OFF.
    8. Ign. OFF.
    Repeat the above the same number of times that is showing on the display when you started. i.e: 10 or 13.
    Please Note that this method will not work with American FIC sets.
    Red keys are primarily used to program the ECU to accept new signals
    It is usually not beautiful key without any knobs, etc.
    3. Radio ON.
    7. Radio OFF.
    8. Ign. OFF.
    Do you have a picture of the red key? Is it supplied with the vehicle? I have Ford IDS, do you think re programing the ecu will change anything?
    genius76's Avatar
    Dec 2012
    Lowestoft
    Not blue only red chip cover
    adam28's Avatar
    May 2009
    UK Essex
    like this mate
    NEVER GET SO BUSY MAKING A LIVING THAT YOU FORGET TO MAKE A LIFE......
    No I think you're mistaken here, all the keys that accompanied
    the vehicle has that red marking indicating its a 4C keys and the blue ones are 4D.
    From Adams post, I understand red keys o ly come with Ford pre 98 and this particular Ford doesn't have the red color key.
    genius76's Avatar
    Dec 2012
    Lowestoft
    Sorry adam28 he is right
    Now that it's established that the vehicle does not have a red key, what is next?
  13. #13
    anthony610's Avatar
    ireland
    set ignition to position one, (not switched on) press and hold number 6 on the radio, it will give you one more attempt but make sure the code is right this time of it will be locked completly, if this dosnt work do the same as above except hold number 2 , it veries for different radios,,, hope this helps
  14. #14
    adam28's Avatar
    May 2009
    UK Essex
    yes you are right the key i showed is for old system.
  15. #15
    genius76's Avatar
    Dec 2012
    Lowestoft
    Something interesting
    https://www.youtube.com/watch?v=fc-EEKvE0Mk
