Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    cotymoto's Avatar
    May 2009
    Default autocom 3/2012 not update firmware
    hi guys, and updated delphi 3/2012, have fileactivation.xml and I recognized vci, the problem is that I always ask update firmaware and will not let me diagnose any car, does anyone has passed this problem?
    morfej's Avatar
    update the firmware.
    Top Poster baner's Avatar
    Quote Originally Posted by cotymoto View Post
    What is your VCI Serial number? Maybe it is blacklisted in this version of the Delphi soft?
    Regards and respect?
    hello, i have similar problem with my old autocom, im using 2011.1 version and after laptop upgrade autocom software tells me that firmware in tester is not up to date.
    When trying to upgrade firmware it thows error.tried to change serial nr. from 30250 to 30221 with tool.exe but result is same.
    Maybe my serial is blacklisted? what serial should i use? or maybe i should try to upgrade firmware with newer version of autocom software?
    or should i manualy upgrade firmware reflashing it by programmer?
    waiting for suggestions! thanks!
    Bucharest
    Quote Originally Posted by bonux View Post
    You have to use the serial from your VCI with HK, after that you have to test it to the car and upgrade the firmware, with the position of the car key to on. It is a process of updating firmare of 5 minutes.
    albujon el
    Hi all, I have the same problem I can not update the firmware Update the device, it tried everything to change the serial number of the probe is useless, what could be done?
    try to solder again flash memory .if not work then programm flash with a programmer with a updated version.
    ive tried to reflash flash memory with programmer with 2011.1 version found here on dk result is same: when trying to test says needs to update, when try to update gives error
    genius76's Avatar
    Dec 2012
    Lowestoft
    I can help you but only if you want me to help you
    All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
    Dunker's Avatar
    Yorkshire
    I've just updated the firmware on both cars and trucks with clone (serial 100251) and sw 2012r3. It does not need to be in car if you can power it up on the bench. Basically I had pins 4 and 5 = GND and pin 16 = 12v.
    I've just read a post on another forum saying the program can be internet updated to 2.12.3.2 and this updates the firmware to v1231. Has anyone had the balls to try this on DK?
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
    Dec 2012
    Quote Originally Posted by Dunker View Post
    Yes true but different solution
    Dec 2012
    Hello ! I have tried to update to 2012.3.2 ( including firmware ) and all works ok. I tried on old vci.
  13. #13
    hi,
    can alll autocom cdp+ be updated to 2012/3 ?
    thanks !
  14. #14
    tehnosoftex's Avatar
    Romania
    Quote Originally Posted by darioyu View Post
    hi,
    thanks !
    Yes, it can. I updated my interface with 100251 serial and all was good. New interface for cdp+
  15. #15
    May 2011
    can you tell us, how you reflash memory?
    on pcb or separatly?
    thanks!
