Results 1 to 4 of 4
    Above sea-level
    Default Daewoo Kalos 2003 1.4 petrol: which ecu type?
    Does anyone know which type of Delco ecu is fitted in a Daewoo Kalos with 1.4 petrol engine from 2003?
    It looks the same as an Opel HSFI ecu, but I have tried to read the memory with carprog - opel hsfi on the bench, but it does not work.
    Ecu number is 96394271
    HSFIx.x?
    i believe it has an old Eprom inside 27c256, with the small UV window. you must remove it and do it with a programmer on a virgin eprom
    Above sea-level
    After some searching I found out it is a MR140 ecu, which should have a 95020 eeprom inside.
    Would be nice to know if this ecu can be read by any tool without having to solder.
    Above sea-level
    Does anyone know how to clone this ecu or copy the eeprom contents to another ecu?
