Hi, does enough to swap flash to second hand ?
Volvo 2002 manual trans 2,4 petrol
second hand 2002 auto trans. 2,4 petrol
It is soaked in water? what do you do with it
I can help you but only if you want me to help you
All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
all CEM s are filled with a brown gel. i had a similar one and never found out how to open withoud damaging them and what eproms to swap to make the immo clone...
Swap the flash
Sent from iPhone 4S
swapped flash , but not helpednew cem with oryg flash connected to car starts nonstop relay clickering, DIM only one check engine light on .
where problem ???
Either your soldering is bad ( clicking relay) or check if cem are identical without any variation.
Sent from iPhone 4S
oryg car manual trans , donor Auto transmision
I think you need to get the right stuff man. Am sure some components will be missing either way. The central locks and windows work? Doubt it.
Sent from iPhone 4S
nothing working![]()
There might be other water damaged controllers, connectors, cables or corrupted flash.
Immo is only in flash and swap works.
It's not only immo that is in CEM, Central locks, power windows , etc are there. So you must get the correct CEM to fix this car. The electronics of both CEM to me are different.
Sent from iPhone 4S
