Results 1 to 10 of 10
    DOUALA_CAMEROON
    Default Audi Q5 2007 rear speed off
    Happy new year to all DK members
    I have audi Q5 year 2007 with rear speed off .in diag there are no possibility to get any information from gearbox ECU .only frnt speed are working . And they change 1,3 & 5 .sometimes engine stop on the road .Can someone tell where this module is located ? any idea to repair this car ?
    Thanks and regards
    Joe
    As far as I know wheel speeds are measured by the ABS and then send via can-bus to the transmission.
    Engine cutting out looks to me as a separate problem.
    Do a full scan with VCDS or similar to get all the trouble codes from all systems.
    DK Veteran ghostridersa's Avatar
    Nov 2011
    I sent you a inbox message about that transmission but when you reply also send me the fault codes.
    DOUALA_CAMEROON
    Thanks for your repply and i will do it early tomorow
    DOUALA_CAMEROON
    here it is
    Diagnostic
    1 02Transmission Electronics
    vin:VWAUKF68R0AA020982
    VW/Audi part number:8R0927156C
    ASAM/ODX fileID: EV_TCMDL501
    ASAM/ODX file version : A02010
    Hardware part number : 0B5927156E
    Hardware version :H03
    System descriptionOB5 20TFSIRdw
    soft version 0015
    fazit identification (manufacture location search): TFK-030
    FAZIT identification (manufacture date) 20/06/2009
    soft module versio :0015
    FAULTS CODES
    fault:08028 description: (2,0,1f,5c) causesassives/abiogenesis descent
    08940 (2,0,22,ec)
    ]ABS[
    Fault code 01315 / description :gearbox control unit/ cause:connector
    ]Engine[
    P157700:rigth engine mount solenoide valve -N145 circuit open
    thanks and regards
    Joe
    Nov 2011
    My friend I checked the vin number of the vehicle, it is a megatronic transmission, which means that the TCM is actually part of the valve body inside the transmission. (In the multitronic transmissions the TCM is in the transmission but not part of the valve body but in the megatronic the tcm and valve body are one unit so if megatronic is faulty you need to replace it as a unit).
    However if I look at the fault codes you are getting I would say that you have a fault in the vehicle wiring or a connector. I will attach a off-line copy of ross-tech wiki. You can go into that folder, click on fault codes and scroll down to code 01315 and it will explain to you what causes that fault code and what to check for to repair it.
    If you need anymore help we can try our best to assist you. Keep us updated.
    Quote Originally Posted by auto diag View Post
    here it is
    Diagnostic
    soft version 0015
    FAULTS CODES
    08940 (2,0,22,ec)
    ]ABS[
    ]Engine[
    thanks and regards
    Joe
    DOUALA_CAMEROON
    this is my problem on picture 630029
    i have two bad (i have two bad solenoides) showing in the picture
    DOUALA_CAMEROON
    Where can i get this hydraulic block ?
    any idea ?
    help please
    Aug 2012
    I HAVE ONE IN GOOD WORKING CONDITION.
    Aug 2012
    any idea ?
    help please
