Results 1 to 15 of 15
    siyadk's Avatar
    Dec 2012
    Default nissan patrol/pathfinder 2000 issue
    hello Dk
    I am not sure why but i always has problem in programming Nissan 2000 models of pathfinder n patrol. I never get communication in t300.
    I used all the possibilty..used nissan cables..used NISSAN 2000 apater...with n without suzuki adapter(a friend recommended)...used OBD cable..but never succeceded.
    I have a strong feeling that its coz of wiring system in obd port..(my only guess)
    so can anyone tell how is it done or how do u do usually with these cars??
    clones is not perfect, does not communicate t300, try mvp, mvp is not communicating, try sbb, sbb not communicating try lunch, csaner etc, etc does not communicate, work, arbajt, on foot, or stubborn and think logically not go easy
    DK Veteran Automat's Avatar
    Chuichu village, AZ
    This pathfinder uses 14 pin OBD socket for key programming I think??
    Sep 2012
    no it was 16pin...obd2
    Chuichu village, AZ
    Quote Originally Posted by ajman5252 View Post
    You need to find a port with this shape 14 pin socket, this is for key programming.
    luis12's Avatar
    Jan 2011
    Panama
    I have same problem, check all conections, lines etc all ok, but imposible to establish comm with ECU, tryed SBB, Hannatech P1, t300, launch etc.. did you resolved?
    Sep 2012
    .I too have same issue.i almost quit on this models.
    Automat ,. Do u mean that this car comes with 2 port,, one exclusively for key programming?
    Yes, have to use 14pin port to prog keys Nat3.
    May 2011
    I'm pretty sure 2000 ish patrols have proper 16 pin obd2 plug
    Just above the accelerator pedal
    The ones in Australia do
    For nissans I've always used my hannatech
    Never tried t300 on nissans
    What motor. Is it the zd30
    Can u use a normal scanner to see if u can actually talk to the engine ecu just to read data
    Tis will tell u if wiring is ok
    luis12's Avatar
    Jan 2011
    Panama
    Quote Originally Posted by sideshow View Post
    Patrol ZD3.0 im sure it dont have 14 pin conn. and hanatech dont connect with this ecu, probably have other protocol.
    May 2011
    U must have issues with wiring or something else
    Is the car all original
    I've wired up afew patrols with a gm ls1 ecu and I know there is nothing different with the patrol ecu compared to other nissans so all good scanner should connect to them
    Sorry I can't check my hannatech on a patrol as most of the ones I work on we remove the zd30 and throw in a gm ls1 or ls2 motor or a big 6.5 litre Chevy diesel
    Chuichu village, AZ
    [QUOTE=sideshow;1858563]I'm pretty sure 2000 ish patrols have proper 16 pin obd2 plug
    They have both 16 & 14 ports on 2000 pathfinder, you have to find the 14 pin one.
  13. #13
    luis12's Avatar
    Jan 2011
    Panama
    Problem solved... the story: This Patrols in Australia; asian market and south america if uses ZD3.0, has a ECU with Zexel software and dont have same protocal than others Patrols, it has same immomodule letter A step5/5.5 with ID60, has I said tryed most key programmers but no success, then a tecnic whith a Gscan made key program kwick and easy, Consult 3 can doit too, Im very impressed with Gscan capabilityes,very good tool.
  14. #14
    May 2011
    Gscan is good but expensive over here and in Australia it does not do all makes and models which my daigun does alot
    I bought launch daigun and found three different bits of software for it
    Merged them all together now I have close to 80 different car logos but half I have no idea what cars they are heheheh
    But for 700 bucks its kicks all over gscan
  15. #15
    Hola for Nissan especially oldies I use VeDis from Autoland Scientech,this is for scanning but it does
    program keys never faild me.There is a new model,
    so if you search maybe u can find one for little money.
    Luis
