Results 1 to 11 of 11
    Senior Member makadam's Avatar
    Nov 2010
    EUROPE
    Default Passat B6 Electric Window Thermal Protection Active
    I have this error codes in my car that appear again after they are erased!
    Also can someone confirm that coding of door driver electronics is ok? (000)181 is not possible to be good because using vcds help and some mathemathics, there is no way to get 181 using codes from help)
    Problem with My car is that does not go in sleep mode and there is battery drain problem!
    Chassis Type: 3C0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72 77 7D
    VIN: WVWZZZ3CZ7P02XXXX Mileage: 207740km/129083miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 021 NK HW: 03G 906 021 AB
    Component: R4 2,0L EDC G000SG 9354
    Revision: --H02--- Serial number: VWZCZ000000000
    Coding: 0000072
    Shop #: WSC 00028 028 00001
    VCID: 75E5E5E76551
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl
    Part No SW: 3C0 614 095 P HW: 3C0 614 095 P
    Component: ESP 440 C2 H015 0004
    Revision: H015 Serial number: 0667610112
    Coding: 0013602
    VCID: 2F69178FC78D
    Address 08: Auto HVAC Labels: 3C0-907-044.lbl
    Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
    Component: ClimatronicPQ46 050 0505
    Revision: 00050005 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 67D9BFAF2FFD
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
    Component: Bordnetz-SG H37 1301
    Revision: 00H37000 Serial number: 00000004193670
    Coding: E1808F0700041A00000A00000F00000000095D435C0000
    VCID: 306B14F3DAB3
    Part No: 3C1 955 119
    Component: Wischer VW461 012 0503
    Coding: 00063445
    Shop #: WSC 00028
    Part No: 1K0 955 559 AE
    Component: RLS 140606 014 1201
    Coding: 00208933
    Shop #: WSC 00028
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 J HW: 3C0 909 605 J
    Component: 04 AIRBAG VW8 029 2521
    Revision: 09029000 Serial number: 003A2PBKBZD1
    Coding: 0012340
    VCID: 2D550D87CD81
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
    Component: Lenks***1076;ulenmodul 005 0010
    Revision: 00005000 Serial number: 3C5953507C
    Coding: 0000013
    VCID: 2A5F069BFC6F
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 871 X HW: 3C0 920 871 X
    Component: KOMBIINSTRUMENT VD1 1614
    Revision: V0007000 Serial number: 00000000000000
    Coding: 0005105
    Shop #: WSC 11111 111 11111
    VCID: 397D29D709C9
    Address 19: CAN Gateway Labels: 3C0-907-530.lbl
    Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
    Component: Gateway 007 0040
    Revision: 00007000 Serial number: 0700C0660605F1
    Coding: 3DFD2C44C61002
    VCID: 214DE1B78159
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
    Component: IMMO 042 0383
    Revision: 00042000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 397D29D709C9
    Part No: 3C0 905 861 F
    Component: ELV 026 0380
    3C0905861F ELV 026 0380
    Address 37: Navigation Labels: None
    Part No SW: 1K0 035 191 D HW: 1K0 035 191 D
    Component: J401 0111
    Revision: 00015000 Serial number: VWZ1Z2F6278085
    Coding: 0043400
    VCID: 2341EBBF9B45
    1 Fault Found:
    00003 - Control Module
    014 - Defective
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 72
    Mileage: 207571 km
    Time Indication: 0
    Date: 2012.12.09
    Time: 00:48:19
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
    Component: J386 TUER-SG FT 1123
    Revision: 12006001 Serial number: 00000044868622
    Coding: 0000181
    VCID: 3B7133DF03F5
    1 Fault Found:
    01034 - Electric Window Thermal Protection Active; Driver
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 254
    Reset counter: 130
    Mileage: 207727 km
    Time Indication: 0
    Date: 2013.01.04
    Time: 00:30:53
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K1 909 144 L
    Component: EPS_ZFLS Kl.135 H07 1806
    VCID: 346318E32EAB
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 042 0472
    Coding: 00910A0001860E7630049C1F70084F0E507C00
    VCID: 397D29D709C9
    Component: Sounder No Answer
    Component: NGS n.mounted
    Component: IRUE n.mounted
    1 Fault Found:
    01134 - Alarm Horn (H12)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 90
    Mileage: 207727 km
    Time Indication: 0
    Date: 2013.01.03
    Time: 23:39:25
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
    Component: J387 TUER-SG BT 1123
    Revision: 12006001 Serial number: 00000047268622
    Coding: 0000180
    VCID: 3C7330C306FB
    1 Fault Found:
    01035 - Electric Window Thermal Protection Active; Passenger
    Freeze Frame:
    Fault Priority: 7
    Reset counter: 130
    Mileage: 207727 km
    Time Indication: 0
    Date: 2013.01.04
    Time: 00:31:01
    Address 53: Parking Brake Labels: 3C0-907-801-53.lbl
    Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
    Component: EPB VC8HC001 013 0001
    Revision: 013
    Coding: 0000011
    VCID: 214DE1B78159
    Address 56: Radio Labels: None
    Component: R 0111
    Coding: 0043400
    VCID: 2341EBBF9B45
    1 Fault Found:
    014 - Defective
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 72
    Mileage: 207571 km
    Time Indication: 0
    Date: 2012.12.09
    Time: 00:48:19
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
    Component: J388 TUER-SG HL 1113
    Revision: 11004001 Serial number: 00000000227921
    Coding: 0000144
    VCID: 3D753DC71DE1
    1 Fault Found:
    01036 - Electric Window Thermal Protection Active; Rear Left
    Freeze Frame:
    Fault Priority: 7
    Reset counter: 130
    Mileage: 207727 km
    Time Indication: 0
    Date: 2013.01.04
    Time: 00:47:33
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
    Component: J389 TUER-SG HR 1113
    Revision: 11004001 Serial number: 00000000228772
    Coding: 0000144
    VCID: 3E773ACB10E7
    1 Fault Found:
    01037 - Electric Window Thermal Protection Active; Rear Right
    Freeze Frame:
    Fault Priority: 7
    Reset counter: 130
    Mileage: 207727 km
    Time Indication: 0
    Date: 2013.01.04
    Time: 00:38:04
    Address 77: Telephone Labels: 3C0-035-729.lbl
    Part No SW: 3C0 035 729 E HW: 3C0 035 729 E
    Component: Telefon 6009
    Revision: 00009000 Serial number: 0000000744765
    Coding: 0016043
    VCID: 2545F5A79571
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    VCID: 2D550D87CD81
    End ---------------------------------------------------------------------
    Ashraf6119's Avatar
    UK
    01034
    Electric window thermo protection active, driver
    -Possible fault cause
    Defective wiring or connectors
    - Electric window sticking or binding
    - Electric window motor binding
    Body self-diagnosis - ElsaWeb
    00003 - Ross-Tech Wiki
    Hope this helps...........
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Senior Member Diagnosticated's Avatar
    Mar 2011
    The door module code is wrong and almost impossible. Have a look here; https://sites.google.com/site/1810ma...at-door-module
    The battery drain is nearly always the stereo/nav. Have you changed it?
    Nov 2010
    EUROPE
    Radio was out but situation was almost same! With radio/navigation there is 1A and without 0.8A which is pretty high. Car just don't go in sleep mode! If some unit(radio/navigation) is out will can gateway search every time because can-h and can-l is open cicuit?
    Nov 2010
    EUROPE
    Quote Originally Posted by Diagnosticated View Post
    BTW what is Automatic Run Active and Door Exit Warning Light Installed?
    Why codding in VCDS help is different?
    Also I dont think wrong coding is problem because Alarm horn also have a fault and some clicking noise coming behind passanger dash, and also sometimes turn light activated without any reason, so maybe problem is confort module!
    Where is located doors control module in drivers door or in every door for that door?
    genius76's Avatar
    Dec 2012
    Lowestoft
    You probably tried encoding new radio or window opening / closing from the key ?
    I can help you but only if you want me to help you
    All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
    Nov 2010
    EUROPE
    Quote Originally Posted by genius76 View Post
    No i didn't try any encoding niether on radio or confort module. Windows are closing with remote by default. I just buy this car and this errors was present even on car dealer place! Main problem is car discharge battery after it was locked. Car never goes in sleep mode. I just ask is that door coding are ok because 181 code is strange
    Send from Samsung Galaxy S2
    We can't help everyone, but... everyone can help someone!
    genius76's Avatar
    Dec 2012
    Lowestoft
    Try it.
    With it easier to understand what is where.
    Find code and click on it, carefully read
    Mar 2011
    Quote Originally Posted by makadam View Post
    Yes unless the system is told not to. Door module is one in each door. I would set door coding to something that makes sense for your car.
    Nov 2010
    EUROPE
    Problem was left driver door, control module has some bad soldering on connector. Thanks for help
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Try it.
    I was searching for this 01034 Electric Window Thermal Protection Active: Driver. That's a new code I haven't found an answer for. So it isn't in your New Folder.rar attachment and you've missed out the ReadMe First.txt file. That's the older version with 7,896 codes the new one has 8,641 at the moment. Users have had the old version for many years. Now I'm not working for along time through no fault of my own, I would like a contribution via PAYPAL for the new version for the thousands of hour spend researching these error codes.
    Keith
    2010 Golf GTD (170)
