Results 1 to 15 of 15
    DK Veteran ghostridersa's Avatar
    Nov 2011
    Default Help Vag fault code 00438
    Good day members of DK
    (Audi A4, 1.8t 2004, RB4) Can some members maybe give some advice on this problem. Connected super vag k + can 2 plus to adjust mileage. Didnt change the mileage but tried, didnt work. But now the fuel reserve light stays on now even thought the tank is almost full and the fuel aguge needle is showing the correct fuel level. Checked fuel sender unit in tank and it is perfect. It is only the reserve light which stays on in the dash. Faunlt code in dash is 00438 - fuel supply sensor 2 G169 (open circuit or connected to plus. Could anyone help with this problem?
    Many thanks in advance
    Top Poster Lidahus's Avatar
    Feb 2012
    Jamaica
    I don't know what's your cluster, but some VAG clusters can be coded for 2 individual fuel supply sensors. Usually only one is connected. Probably you had enabled the second one which of cause isn't connected.
    batandball's Avatar
    May 2011
    Quote Originally Posted by ghostridersa View Post
    use some airbag tape or engine management tape to cover light
    If it works use it
    BatandBall
    Nov 2011
    Hahaha, looking to solve the problem not hide it.
    Quote Originally Posted by batandball View Post
    miha99's Avatar
    EU
    k+can has changed wrong bytes.
    Nov 2011
    Thanks for the info, how would I correct this?
    Quote Originally Posted by miha99 View Post
    d2mike's Avatar
    Europe
    Post what type of car and the part number of the instrument cluster.
    Nov 2011
    @ d2Mike, thanks for your reply. It is a 2004 Audi 1.8t with RB4 cluster. Vehicle is not here now so don't have part number.
    Quote Originally Posted by d2mike View Post
    d2mike's Avatar
    Europe
    Ok. Do you have the dump of the dashboard?
    Nov 2011
    No I don't have the dash dump. Customer needed the vehicle and is bringing it back to me on the 17th of this month.
    DK Veteran kams20040's Avatar
    thats the reason why i tell donttouch with the shit chinese tool maybe on golf4 1998 ect...... but after dont try you will have surprise
    d2mike's Avatar
    Europe
    Alright. So if you have the car again in your workshop, post the dump and the coding of the instrument cluster.
  13. #13
    Nov 2011
    Thanks my friend I will do that. Thank you. I have a feeling that the dump is corrupted.
  14. #14
    hello I have same problem with MK5 . car have only one fuel sensor but cluster looking for second one. know anyone where in eeprom I need change it?
    I have dump and can post it hereif it is needed cluster is 5N0920870D
  15. #15
    Aug 2015
    Latvia
    Connect to cluster with VCDS and check codding and adaption channels , may be you can change fuel sensor- one or two sensors activated.
