Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 59
  1. #31
    Feb 2013
    Need to access files for download. Trying to fix my friends wii which has similar problem with usbloader crashing. Hope it's not his menuify mods which have broken it!
  2. #32
    Jun 2013
    I am going to try this tonight because ever since i updated wiiflow and changed my HDD i have had problems with DSI error, fingers crossed
  3. #33
    Jul 2013
    I'm getting the same error message. Will give this a try. Thanks.
  4. #34
    Jul 2013
    Hi all.
    I had this error pop up the other day when my son tried to play a game. I have no idea why it suddenly happened, but I'm guessing they did something to screw with it. Since my HBC was very out of date and USBLoader was still version 1.0, I started trying to upgrade everything.
    I got d2x v8 and installed everything in it, but USBLoader was failing to run (it would drop back to the Wii channel screen). When trying to run from HBC, USBLoader would complain about missing/stubbed cIOSes.
    I got all of the wads listed on page one of this thread (the full cios pack, the "my wad pack", etc.). I put MMM that came with the full cios pack along with the wads on the sdcard and installed them all.
    I then got a fresh copy of the USBLoader_GX_V3_0_AllinOnePackage_IOS249.zip and installed that on the sdcard. I erased the old forwarded channel and re-installed the forwarder.
    Now, USBLoader runs from HBC, but drops back to the Wii home screen when I try to run the forwarder channel.
    The only thing I notice in syscheck output is that I don't have an IOS236 -- is that the problem?
    sysCheck v2.1.0b19 by Double_A and R2-D2199 Nano
    ...runs on IOS61 (rev 5405).
    Region: NTSC-U
    System Menu 4.3U (v513)
    Priiloader installed
    Drive date: 2008.07.14
    Homebrew Channel 1.1.0 running on IOS61
    HomebrewFilter ist nicht installiert
    Hollywood v0x11
    Console ID: 88541435
    Boot2 v4
    Found 82 titles.
    Found 47 IOS on this console. 5 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 16174): Trucha Bug NAND Access
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 16174): Trucha Bug NAND Access
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 16174): Trucha Bug NAND Access
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3091): No Patches
    IOS34 (rev 3348): No Patches
    IOS35 (rev 3349): No Patches
    IOS36 (rev 3351): Trucha Bug ES Identify NAND Access
    IOS37 (rev 3869): No Patches
    IOS38 (rev 3867): No Patches
    IOS40 (rev 16174): Trucha Bug NAND Access
    IOS50 (rev 16174): Trucha Bug NAND Access
    IOS51 (rev 4864): Stub
    IOS52 (rev 16174): Trucha Bug NAND Access
    IOS53 (rev 5406): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5661): No Patches
    IOS60 (rev 16174): Trucha Bug NAND Access
    IOS61 (rev 5405): No Patches
    IOS70 (rev 16174): Trucha Bug NAND Access
    IOS80 (rev 16174): Trucha Bug NAND Access
    IOS202[60] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
    IOS222[38] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0
    IOS223[38+37] (rev 4 Info: hermes-v4): Trucha Bug ES Identify NAND Access USB 2.0
    IOS224[57] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
    IOS245[37] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS246[38] (rev 21008 Info: d2x-v8final): Trucha Bug ES Identify NAND Access
    IOS247[53] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS248[55] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS249[56] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS250[57] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS251[58] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2013/07/27.
    Any help would be greatly appreciated before the kids drive me insane.
    Thanks,
    -L
  5. #35
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Welcome to DK.
    Homebrew isn't out of date its 1.1.0 the same as mine.
    I don't know who's softmod tutorial you followed but there is one IOS missing totally IOS236 I don't know how any game attempts to run.
    There are a few IOS's that need updating. The easiest way is download ModMii6.2.7 and run it from Windows. On the main menu type in SU and type in the location of the sysCheck.csv from the sysCheck. Its easier to put this on the root of a drive as it saves typo's.
    That will download all wads and apps that are missing into a COPY_TO_SD sub folder. Add all files and folders to your SD card and run Homebrew with the SD card inserted.
    First of run IOS236 Installer v5 Mod and install IOS36 as IOS236, you must do this before you install any other wads. Come back out and run Multi-Mod-Manager and select WAD Manager this will default to the wad folder install all wads in there, read the instructions at the bottom for which buttons to press. Install the other wads that ModMii gave you, watch for the Installed OK message after each one. If any don't install just try them again.
    If you want to remove IOS16 Stub then install my cIOS16-v257 that won't improve anything only remove that Stub.
    You will find that the Shopping Channel won't work anymore it will say you need to do a system update but don't bother just download and add RVL-Shopping-21.wad to the wad folder and install it with MMM. RVL-Shopping-21
    Then post a new sysCheck.
    Keith
    2010 Golf GTD (170)
  6. The Following User Says Thank You to Keithuk For This Useful Post:
    levins0 (28th July, 2013)
  7. #36
    Jul 2013
    after 6 months of using my Wii with GX loader I also had this error just pop up. I am trying different things to see what will fix it but for the life of me I cant work out what caused it.
  8. #37
    Jul 2013
    Thanks, Keithuk!
    I knew 236 was missing, but didn't know why. I originally modded this thing a few years ago and haven't done much with it since except rip games to the HDD and happily use USBLoader.
    I think what happened is that one of the kids put a game in the drive, and the "system update" popped up, so they selected it but cancelled. That screwed some stuff up.
    I was trying to fix it myself coping files to the SD card instead of installing and using ModMii, but I'm now a convert. That was really easy!
    Here's the updated syscheck, which now reflects a fully working system with the latest USBLoader forwarder:
    ...runs on IOS58 (rev 6176).
    Region: NTSC-U
    Hollywood v0x11
    Boot2 v4
    Found 90 titles.
    Found 55 IOS on this console. 4 of them are stub.
    IOS16 (rev 54321): Trucha Bug ES Identify Flash Access NAND Access
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS53 (rev 5663): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug ES Identify NAND Access
    BC v6
    MIOS v10
    Thanks again!
    -L
  9. #38
    Aug 2010
    England
    Welcome to DK.
    Quote Originally Posted by mybrains View Post
    If you had a brain like your username says you should have posted a sysCheck19 report as instructed in that link, just like levins did without asking.
    Keith
    2010 Golf GTD (170)
  10. #39
    Aug 2010
    England
    Strange thing happened to mine today. I updated WiiFlow from 2.2 to 4.2 to try it out. I played a game no problem but when I exited it should go back to WiiFlow but it didn't if showed the same screen as the picture Exception (DSI) occurred. It counts down reloading in XX seconds but it doesn't reload anything I had to turn it off to reset it. I didn't like 4.2 so I put 2.2 back and things exit as they should. I've never had this error before.
    Keith
    2010 Golf GTD (170)
  11. The Following User Says Thank You to Keithuk For This Useful Post:
    B3lvedere (10th October, 2013)
  12. #40
    Oct 2013
    Hi everybody,
    Hope you can help me. I've been trying to get a Wii modded correctly for weeks now.
    Already tried various SD cards and 2 different harddrives that work on another Wii. I can't seem to find out what's going on.
    It used to work perfectly with USB Loader GX, then somebody messed things up and now i can't seem to get the USB to work anymore.
    USB Loader GX and Configurable Usb Loader will not recogize any hard drive. WiiFlow will recognize it, but trying to start a game ends up in a DSI error.
    Here's the syscheck:
    sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
    Region: PAL
    System Menu 4.3E (v514)
    Drive date: 2007.02.13
    Homebrew Channel 1.1.2 running on IOS58
    Hollywood v0x11
    Console ID: 72203436
    Boot2 v4
    Found 93 titles.
    Found 54 IOS on this console. 5 of them are stub.
    IOS11 (rev 256, Info: rev 10): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS15 (rev 257): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS20 (rev 256, Info: rev 12): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS30 (rev 2816): Trucha Bug, ES Identify, Flash Access, NAND Access
    IOS36 (rev 65535): Trucha Bug, ES Identify, NAND Access
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): Trucha Bug, NAND Access
    IOS43 (rev 3607): Trucha Bug, NAND Access
    IOS45 (rev 3607): Trucha Bug, NAND Access
    IOS46 (rev 3607): Trucha Bug, NAND Access
    IOS48 (rev 4124): Trucha Bug, NAND Access
    IOS50 (rev 5120): Trucha Bug, NAND Access
    IOS51 (rev 4864): Trucha Bug, NAND Access
    IOS52 (rev 5888): Stub
    IOS60 (rev 6400): Trucha Bug, NAND Access
    IOS62 (rev 6430): Trucha Bug, NAND Access
    IOS70 (rev 6912): Trucha Bug, NAND Access
    IOS80 (rev 6944): Trucha Bug
    IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
    IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
    IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    BC v6
    MIOS v10 (DIOS MIOS 2.6.1+)
    Report generated on 2013/10/10.
    Should you require any additional information, feel free to ask.
  13. #41
    Aug 2010
    England
    There doesn't look anything seriously wrong with that sysCheck apart from IOS16 but thats no big deal.
    Well if WiiFlow shows the Exception (DSI) occurred like me then you need to put back an older version like 2.2 as I found out a couple of days ago.
    If your using the latest USB Loader GX 3.0 there shouldn't be a problem. CFG USB Loader should be v70 on its own not 222 or additional numbers.
    Keith
    2010 Golf GTD (170)
  14. The Following User Says Thank You to Keithuk For This Useful Post:
  15. #42
    Oct 2013
    Quote Originally Posted by Keithuk View Post
    Thank you for your quick reply Keith. Would it make any difference if i repaired IOS16? Perhaps i could use PimpMyWii for that.
    I think i downloaded the latest version of CFG USB, but i will make sure to check that again. Where can i find an old version of WiiFlow?
    Thanks again for your support.
  16. #43
    Aug 2010
    England
    As I said installed IOS16 won't really help your problem but if you want to remove the Stub then download cIOS16-v257 and add that wad to the wad folder on the SD card and install it with Multi-Mod-Manager (MMM) v13.4.
    Now because the older WiiFlow 2.2 isn't available to download I've now added it in the Wii Dowloads section WiiFlow2.2-249. If your having problems when you exit WiiFlow with the Exception (DSI) occurred error then add this older version to the SD card and try it.
    Keith
    2010 Golf GTD (170)
  17. The Following User Says Thank You to Keithuk For This Useful Post:
  18. #44
    Oct 2013
    No luck yet. WiiFlow 2 will pop up with the picture to insert a USB harddisk in the slot.
    I've also updated PriiLoader, but that didn't do much good either.
    I'm now trying to reinstall system menu 4.1 and perhaps reinstall the whole bunch of IOS wads.
    Is there a way to start all over again and could that actually help?
  19. #45
    Aug 2010
    England
    Well the ideal way to get it close to the original 4.1 is to use the NAND restore thats if you did a NAND backup when it was softmodded, thats doubtful.
    The other this is uninstall PriiLoader or disable online updates and let it update to 4.3 then resoftmod correctly with LetterBomb, personnally I would use this option.
    Keith
    2010 Golf GTD (170)
