Results 1 to 3 of 3
Thread: Allison MD3060
    DK Veteran dimitar22's Avatar
    Jan 2009
    Default Allison MD3060
    I have problem with this transmission it is mounted on volvo FL truck year 1999, the code i get from the transmission shift selector is 4627-over current A-hi solenoid, i checked the wiring, measured the resistance of the solenoids all is ok.
    Replaced the ecu from an other truck and the problem remains.
    Please help i don't know what to do any more.
    can you disconnect the blue connector and use a low current probe to see how many amps it is drawing? pretty sure you can even use Allison doc and monitor amps.
    Share on!!!
    Jan 2009
    Solenoid B was drawing 12 amps, all the other solenoids draw 5 amps. I replaced solenoid B and there are no fault codes.
    There is one problem when i try to go forward it starts to go with 5 th gear.Tomorrow i will do a test drive to see what will hapen.
