Results 1 to 12 of 12
    Dec 2011
    Nottingham
    Default Almera Tino 1.8 Ignition coil problems MEC32-410
    Hi all,
    I have a Nissan Almera Tino 1.8 2003 with a starting fault. Originally the car had a misfire, 2 of the coil packs had a very weak spark so they were changed and the car ran sweet for about 44 miles. Then it cut out and misfired worse than it did originally.
    Knowing this has a common ECU fault I got a known working ECU, code swapped and changed all 4 coil packs this time. Car ran for 2 miles then died. Now it doesn't start. Crank but no fire!
    I've looked in the ECU and the coil driver looks intact, and it no way gives a direct 12 volt output. So my 2 questions are:
    Is there any sort of coil amplifier between ECU and coil packs (to go from 2v to 12v) which could cause the fault?
    Are their any other known issues I should be aware of?
    As always your help is greatly appreciated.
    genius76's Avatar
    Dec 2012
    Lowestoft
    no start check crankshaft sensor
    these engines ignition coils hated moisture
    by the way ECU and ignition coils power supply with one double relay if i good remember because a long time ago I had in my hands such a vehicle
    I can help you but only if you want me to help you
    All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
    Dec 2011
    Nottingham
    Thanks for your input. Crank is good, I can see rpm signal when I look at live data. Three wires are going to each coil, I am led to believe middle is power and the outer 2 switch earth. I haven't got power at any of them. Nissan told me the relay location which I switched over with another so I am led to believe it is wiring going to the coils Any other suggestions?
    Dec 2011
    Nottingham
    Can you remember where the double relay is?
    genius76's Avatar
    Dec 2012
    Lowestoft
    i rely don't remember I only remember that I had a car it was baked relay and sometimes ecu f..k sometimes ignition coils until replaced relay
    maybe is helps
    cjawahir's Avatar
    T&T
    hi look on passenger side remove glove box and look next to the blower and side panel , you will see brown relay .
    when you turn ignition on this relay should click , check fuse in engine bay .
    if the fuse is blown disconnect the idle valve and try again .
    this vehicle is electronic throttle or not ?
    cj
    Meat-Head's Avatar
    we had a micra come in short story was no run run
    went straight to the blown 20 amp fuse - as could see a hole in the coil
    sent it on it's way on 3 cyclnders all well and good
    gets a phone call hour later, they robbed a coil out of a running car in parking lot it now died.
    we never dared ask what the outcome was.
    did see a car of the same color in thier parking lot part stripped, so no idea.
    Dec 2011
    Nottingham
    Thanks for the suggestions guys. Ended up stripping the loom to find a few wiring faults.It's been ok for 4 days so problem solved. Thanks
    cjawahir's Avatar
    T&T
    Quote Originally Posted by Autowave View Post
    and the fault was ?
    Dec 2011
    Nottingham
    2 heavily corroded wires and another 2 had melted together.
    Meat-Head's Avatar
    what size eengine and where abouse in the loom?
    the micra we had, we tried to bend it, shape anyway we wanted it, with test light on it nothing bad happened.
    Dec 2011
    Nottingham
    They were just near the plastic housing to the right of the coils. I had some night vision goggles on as well, my lead light ran out of batteries
