Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 46
Thread: nbox hd enigma2
  1. #16
    DK Veteran portbhoy's Avatar
    Sep 2008
    The reason they are half the price is that they have not been modified to run enigma 2 and is basically just a provider box unable to do anything else unless you can read polish and are really good with a soldering iron. As for it being a starter box, thats also a no go you need some knowledge of enigma 2 and oscam to set it up properly.
  2. #17
    Jan 2013
    Interesting box reminds me of the dbox days .....
  3. #18
    Feb 2013
    Go onto the Sataid forum there is info there. The box does come in English and the reason for cost is that they have to have a lot of wires soldered, reprogram a chip to receive Enigma 2, then have the image flashed and get it working. The 3 month guarantee is on his work. The box itself is great once working but it will be a steep learning curve. Polish forum here - hxxp://pkteam.pl/viewtopic.php?f=96&t=5137&sid=08a0d2e681754cd3f65c 1158354bae1d translate with Google Chrome
  4. #19
    Feb 2013
    Quote Originally Posted by taff2412 View Post
    hi i did buy the box, channel lists easy to install with dreambox edit etc, and i use dcc to ftp to box, picture quality is good and with the new openpli image crossepg works, couldnt get it to work with other images. had a few minor issus, when you restart the box i have had to manually restart the network but no big deal i suppose. only other problem is i cant get it to move my motorised dish, playing around trying to fix it now, not sure if its the enigma images as i just tried the same on an amiko alien 2 and same result
    here you go mate had a look specially for you
    Quote - Right, got the motor to work. Posting as this is likely to be vital information for anyone else who buys one of these intending to run a motor
    Cable 1 from Motor to LNB IN 1 on nBox
    Cable 2 from LNB(Misses motor) to LNB IN 2 on nBox
    In tuner setup menu
    Tuner B is actually LNB IN 1
    Tuner A is LNB In 2
    They are switched around in the software only - so keep your cabling the same as any other setup. Quote end
  5. #20
    can any one tell me how to download install cross epg, pleases
  6. #21
    Feb 2013
    Quote Originally Posted by the man View Post
    On the nbox 5800sx? If it is the Nebula Zero v2 image has it built in. You go into Crossepg settings, Into configure and ensure Harddisk is chosen or USB. Also choose update every hour in standby if you want to. Then go into your OpenTV provider. Choose 28.2 Sly and download. Then go into download and this can take a while. Once done reboot and it should work but go back into Crossepg settings and ensure you have harddisk chosen.
    Before doing all this ensure you have setup your tuners and configure them with Sly 28.2 info. You get stuck give me a shout.
    As to the above post from Portbhoy - Oscam is easy to setup and it does work but I use Oscam 4158
  7. #22
    Thanks , iv got openpli with oscam alreasy set up , may try Nebula Zero v2 at some piont but may need a hand. , is it easy to change images and set the new images up on nbox twin box ? Thanks.
    Done now.
  8. #23
    Feb 2013
    doesnt take more than 15 minutes to complete the image upgrade
    Is OpenPLI a good Image what you get on it?
  9. #24
    Default nbox
    hi when you were loading channell list wit d/bedit did you use dreambox as the password as i have one and it wont let me send channell list to it . cant connect
  10. #25
    Feb 2013
    jken the details are:--
    Login: root
    Password: pkteam
  11. #26
    Apr 2011
    Default record
    any one got problem recording i have to watch the same channel while recording tried everything any help
  12. #27
    Default help
    Quote Originally Posted by anniemay View Post
    have you got 2 feeds into back of receiver from dish also you have to tune both tuners in for it to work.same thing happened to me, supplier only tuned one tuner in,hope this helps.jim
  13. #28
    Oct 2012
    Quote Originally Posted by tomthered View Post
    will this give a full epg or just now and next
  14. #29
    Feb 2013
    Quote Originally Posted by baisha View Post
    Its full 7 day EPG once you downloaded data and set up the twin tuner satellite channels
  15. #30
    Oct 2012
    i have been trying to get it working for days now finally got it running now
