Results 1 to 15 of 18
    Senior Member mauronow's Avatar
    Sep 2012
    Default Bosch ME 7.1.1 helpME please !!!!!!!!!
    Hello friends! sorry for my bad english...
    Please I need your help,
    The car is a WV Vento (Jetta) 2.5 170 HP gasoline
    I have read the file with galletto obd2, i read as golf 5 ME CAN 7.1.1.
    The reading was in 32 minutes, READING OK.
    Then I open the Titaniu m.. and detects the driver as I Vento 2.5 170 HP Perfect!
    Then edit the file and upload it with galletto also.
    -Now the car will not start, just turns but does not start the engine.
    -I read with Galleto and gives me the info wrong data in info.
    - As I put the ECU in boot mode to enter the file galletto who read the first time?
    -The file is 1mb, titanium detected OK!
    - I do not find as plug out of the car to enter the file good
    Attached photo of the ecu and read the first file of 1 mb.
    Can you help please? In the photos of galletto ecu not get this, is not equal to the photo. look good.
    In pinout galletto photos this ECU not there similar.
    Thank you!
    I hope answers ..
    Nov 2008
    places
    me7 uses k line to flash. not canbus.
    you only need 12v, ground, k line connection to ecu. flash in bootmode.
    your original read seems bad.
    genuine tools owned: too many
    genuine software owned: have lost count
    Sep 2012
    Quote Originally Posted by k0mpresd View Post
    Thanks, but I have a photo of boot mode.
    In galletto photos of cd, are not equal. good look at them.
    file that you recorded =?
    Nov 2008
    places
    pins are same as me7.5 bootmode. i have done these 2.5l me7.1.1 ecus before.
    here is 150hp file. maybe you can at least recover in bootmode using this file.
    ARE YOU SURE titanium corrected the checksum??
    Dec 2010
    Hello
    This is ME7.1.1 ST10 ecu!! Will not write over OBD with clone tools. US models have checksum in processor active, so flash + processor must be tuned.
    With attempt to OBD write you killed eeprom and maybe processor content.
    greetings,
    filecloud
    Sep 2012
    Hi I have 7.1.1 boot mode
    Galletto2 reading OK !!
    ID OK !
    I need to charge an original file with galletto to revive the ecu with galletto
    NO I have the full file.
    Dec 2010
    Quote Originally Posted by mauronow View Post
    ID OK !
    Your first OBD readout is 100% OK.
    greetings,
    filecloud
    Sep 2012
    Quote Originally Posted by filecloud View Post
    greetings,
    filecloud
    I have but the bad read. only has 1mb. and when I charge it tells me error galletto checsum.
    i need original full file .
    Dec 2010
    Your flash read is OK!!!!
    You need to fix your ST10 processor content and your eeprom...
    Sep 2012
    hello I can explain how I do it? please.
    I fix the st10f275?
    thanks friend!
    Dec 2010
    thanks friend!
    You can use Byteshooter ST10 toolbox and ersa/beeprog for the eeprom.
  13. #13
    Sep 2012
    I have a g-4x to read. where byteshooter him? is a software?
  14. #14
    Default re
    Post eeprom I will fix it
    st10 no need to be tuned only flash most be
  15. #15
    Sep 2012
    Quote Originally Posted by rsivan View Post
    to improve performance need only modify the 29f800bb? or do I have to do a full reading with galletto in bootmode of micro + flash?
