Results 1 to 15 of 18
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Default LTU & LT3.0 Download + Jungleflasher
    FW Pack
    C4E***8217;s iXtreme LT Ultimate in association with Team Jungle & Team Xecuter
    Official release of the iXtreme LT Ultimate for Team Xecuter LTU PCB
    - Support for Liteon 0225, 0401, 1071, 1175, 1532, Hitachi 0500/0502
    - No need for firmware dump of source drive. Requires dvdkey and J-Runner data
    - Supports enhanced topology data if present for more accurate topology responses (Future ABGX support)
    - Requires new JF to support LTU board flashing process. Use 0800 dual layer disc in drive to enable reflashing/vendor mode once LTU is written to board
    This firware is uniquely written for the TX LTU board. It has all the features of LT 3.0 with the addition of the LTU features.
    The 1332 chip has been the most secure chip used in the 360 to date. Cudos to MTK/Liteon for their attempt.
    The movement of the dvdkey, AES routines and realtime firmware checks into the drive CPU was a nice touch.
    I would like to dedicate this release to fellow countryman and Commodore hacker Julian Assange and Wikileaks. Keep the bastards honest.
    Thanks go to Team Jungle and all testers for their hard work and efforts in the development process.
    Thanks also go to Team Xecuter for their support to this project.
    JungleFlasher
    JungleFlasher 0.1.94(320)
    Support for new Key verification process
    Vendor command support for DG-16D5S Drives
    -xecuter X360USB Pro ***f/w update required***
    -xecuter X360USB Pro 2 ***f/w update required***
    Extra functions to utilise RGH extracts with LTU using T-X DG-16D5S replacement PCB
    Support for LT Plus 3.0
    -Hitachi 78, 79
    Support for LTU 1.2, using T-X replacement PCB
    -liteon DG-16D5S  1175, 1352
    -liteon DG-16D4S  0225, 0401, 1071 - lost f/w replacement, replaced with a T-X DG-16D5S replacement
    -hitachi DL10N 0500, 0502 - replaced with a DG5S
    Bug fix to SlimKey for bytes at 3f005, 3f006
    IO port enumeration for Win 8 using old school PCI bus scan
    -Using new portIO drive from schtrom with 32bit memory access
    Jrunner & Tut links to follow but if you have a clue you should be sound
    This is the PCB required TX Liteon DG-16D5S - Replacement PCB 1175+ - 360 Firmware - Xbox 360 - MTUK LTD
    Jrunner (From RMS) http://www.realmodscene.com/index.ph...&attach_id=385
    - Added support for LTU required files on "Extract files" function for use with JungleFlasher
  2. The Following 9 Users Say Thank You to cunny For This Useful Post:
    ablueheron (29th March, 2013), adeys (25th August, 2013), CweLe (18th April, 2020), freez4u (8th January, 2025), gnesper (21st November, 2019), Z33K97 (18th April, 2025)
  3. #2
    cunny's Avatar
    Jan 2009
    The Shoutbox
    In the jf manual an on tx forums
    Sent from my GT-I9300 using Tapatalk 2
    Feb 2013
    this is realy LTU firmware? because i cant found anywhere to download thank u
    Feb 2013
    is it possible to write to the new LTU pcb with dumps taken from the original drive the 16d4s
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Quote Originally Posted by unique904 View Post
    Try it as I no dumps to try
    Top Poster + casper1690's Avatar
    Feb 2011
    scotland
    hi cunny. now the software is hear. do i now buy a ck3 kit as image a pm u before. also now use the software and use the guide in ur other tut. thanx and sorry for pm all time
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Quote Originally Posted by casper1690 View Post
    You will need
    DGX If you need to pull info off motherboard of 360.
    Replacement PCB (LTU)
    x360 USB v2
    Or take it someone who can do it for you as the above could be costly
    Feb 2011
    scotland
    Ok al just pay 40 get it dne thanx. Then could u give me info on wether or not my multi dvd drive will do deul layer dvds. As did 1 in past but it unflashed my mates xbox I think
  10. #9
    cunny's Avatar
    Jan 2009
    The Shoutbox
    The hitachi will be more than 40. The pcb alone is 40. I co retrieval e about 20
  11. #10
    Feb 2011
    scotland
    Ok. Thanx. Will c if any1 can do it for me
  12. #11
    cunny's Avatar
    Jan 2009
    The Shoutbox
    I can put you in touch with people.
    http://team-xecuter.com/forums/showthread.php?t=99737
  13. #12
    Feb 2011
    scotland
    i am in scotland do u have a idea of price. p.s will i b able to do discs and from a external 500hdd
  14. #13
    Apr 2013
    Thank you for posting these files
  15. #14
    Jan 2020
    Thank you. I am trying to flash an old lite on xbox 360 drive with 0800 fw for ripping a game my classic xbox cant read. Cant believe i lost the 0800 fws.
  16. #15
    Jan 2020
    So I had to spam-post and wait several mins to download the fw pack for the 0800. I was able to download n older version of the JF i already have but not the fw. Rules are rules, but hey, if that file required a "higher level for VIP ppl" would have saved time for me and storage space for the forum.
