Results 1 to 11 of 11
    DK Veteran JOHNCICY's Avatar
    Mar 2011
    EAST AFRICA
    Default VW Bettle check sum error - Internal Control Module; memory check sum error p0601
    Hey mates i need repiar for ths dump.- Internal Control Module; memory check sum error p0601 plus immo off.Thanks
    Shmortz's Avatar
    in the middle of nowhere
    flash checksum is OK, I think you should look for good eeprom dump for that ECU...
    Mar 2011
    EAST AFRICA
    Quote Originally Posted by Shmortz View Post
    Thanks Shmortz for thar verification
    Can some plz help with good dump with 24c04 eprom plus immo off solution.ThanksB
    Mar 2011
    EAST AFRICA
    Quote Originally Posted by JOHNCICY View Post
    No one mates with ths data.!
    Jun 2009
    you can search similar ecu that have this memory and use it for you ecu .its easy to make immo off .your problem is the memory
    yugo45's Avatar
    Post you eeprom file , I think I can fix it.
    Post eeprom dump
    Junior Member radeon's Avatar
    Feb 2013
    What type of ECU?
    If it MED9.xx - you need reprogram ECU latest SW version via CAN!, not BDM!, for exapmle, VAS5054 and VW Flash disk.
    yugo45's Avatar
    Quote Originally Posted by radeon View Post
    What type of ECU?
    This is ME 5.9 and it is not software problem. It is Eeprom problem.
    Mar 2011
    EAST AFRICA
    Quote Originally Posted by yugo45 View Post
    Here is the original eprom.
    Quote Originally Posted by gadroulll View Post
    IM looking for another dump today will test and report.
    Mar 2011
    EAST AFRICA
    problem was solved.........got another dump flash and eprom....immo off.
