Results 1 to 4 of 4
    Jul 2008
    Default newcamd vs mgcamd? same thing?
    I have a clone DM800 HD PVR clone running the openpli-2.1-beta-dm800-20130126-sim2-ssl84b image.
    I have been running cccam and using test lines to test the emulator and that works fine, by default on the image mgcamd wasn't installed so I installed it via the plugin menu's.
    I am trying to configure the mgcamd emulator and had a few questions:
    If i want to add test lines i am guessing for this openpli image it would be /var/keys/newcamd.list?
    I have deleted everything in this file and just put the following in
    CWS_KEEPALIVE = 300
    CWS_INCOMING_PORT = 21000
    CWS = hostname port username password 01 02 03 04 05 06 07 08 09 10 11 12 13 14 wan server
    CWS = Server-Host port *username password* 01 02 03 04 05 06 07 08 09 10 11 12 13 14 wan server
    when I restart the emulator it doesnt seem to work?
    Does anyone know what I am doing wrong? Does this method apply for Mgcamd or is this for newcamd? What is the difference?
    I have also have tux box installed and in /var/tuxbox/config/newcamd.conf I see an entry where I could put a CWS file. I have tried in here and it doesnt work.
    Any step by step tutorial links would be very helpful as I am really stuck.
    V.I.P. Member chic.'s Avatar
    Feb 2009
    glasgow
    Quote Originally Posted by isotonic_uk View Post
    CWS_KEEPALIVE = 300
    hi m8 you put it in usr/keys reboot box then restart mgcamd
    if i helped hit the thanks btn
    Jul 2008
    Quote Originally Posted by chic. View Post
    Ok thanks for clarifying that. So for Mgcamd it always goes in the newcamd.list?
    So the way the text file i have shown above. Do the settings seem correct?
    Anyway i can test this?
    Feb 2009
    glasgow
    Default dm800hd
    yes thats ok but dont delete anything in usr/keys there should be a mg_cfg there
    i have sent a pm about testing
