Ready look in first post
Lexia/PP2000 and DiagBox update without internet
http://www.digital-kaos.co.uk/forums...ternet-155768/
http://www.digital-kaos.co.uk/forums...86/#post806086
new update V7.47 ready to first post![]()
admiralx (15th July, 2014), alfabug (7th July, 2014), cubica1 (5th July, 2014), esse (6th July, 2014), jos68 (7th July, 2014), kitty-hawk (6th July, 2014), paro44 (7th July, 2014), shirokov (11th July, 2014), smirnoff_rules (5th July, 2014), xilophene (5th July, 2014), yellowstilo (5th July, 2014)
Dear scarymistake, I wish to thank you, also to Luis andre, for all you done for all of us!!! You are perfect, both of you!!!
THANK you very much!!!!
great regards,
cuby
scarymistake (5th July, 2014)
tupdate v7.49 in first post
admiralx (15th July, 2014), gieteknysa (18th July, 2014), jos68 (12th July, 2014), kitty-hawk (11th July, 2014), Master01 (11th July, 2014), move (13th August, 2014), paro44 (11th July, 2014), shirokov (11th July, 2014), wiseman (16th July, 2014), xilophene (11th July, 2014), yellowstilo (10th July, 2014)
How can i used my clone interface with 7.49? ive installed it ok but it wants to reflash unit
BR
If you have problems with your interface you need to contact scary and he will sort them for you.
dk hello good morning, I have a problem opening diagbox,
Activation asked me now I give to cancel and did not open.
and give it to activate it fails and does not work on internet.
full uninstall and I started from scratch again
but when I go to activate it manually skip a mistake.
can help
solvent![]()
1) Use Cleaner DiagBox, then clean files from previous installations failed the DiagBox
2) Run CCleaner to clean registry
3) Go to: Windows Start / run then type "regedit" and check if you see some log files named "Diagbox" or "actia" folders HKEY_CURRENT_USER HKEY_LOCAL machines and users, then delete manualy
4) Check if the drivers are properly installed, the wi-fi card in the PC-Laptop
5) Check if the installed driver LAN card right
6) Turn on wi-fi, connect the network card to connect to the ineternet DiagBox ALL times during installation
Scarymistake,
If I want newest Diagbox,I must update my device.
Your PM is full,please clear and contact me.
Regards,
Sima
After installing software from first post I get the following Error,anyone help please?
take out the interface from usb and recconect...and will be ok
