Results 1 to 12 of 12
    Dec 2012
    Default 2005 NISSAN MICRA K12 U1001
    Hi guys was wondering if anyone could help i had a customer in today said he had abs fault said last mechanic cleared a code but it didn't turn dashlights off
    i had scanned all systems only code i keep getting is U1001 - (CAN communication Permanent) on the brake system (no comunication)
    all other systems are ok no problems.
    the lights on the instrument cluster that are on constant while driving EML,ABS,PARKING BRAKE also the speedometer has stopped working
    i have them booked in for monday morning trying to see if anyone else had previous experience/problem and solution if any
    thanks in advance
    genius76's Avatar
    Dec 2012
    Lowestoft
    100% no 12v
    I can help you but only if you want me to help you
    All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
    Dec 2012
    Quote Originally Posted by genius76 View Post
    100% no 12v
    not sure if i'm correct do these cars suffer -Ground wiring problems ?
    DK Veteran NZBrakelathes's Avatar
    Aug 2010
    Zibo Shandong China
    Battery leaked on abs unit??
    Dec 2012
    No abs unit definitely clear from battery acid
    Ashraf6119's Avatar
    UK
    There are about 5 fuses in Engine Bay fuse box some are F49-10amps F29-40amps, F34-30amps, F36-60amps, and F1-80amps, all located in Engine Bay............
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Dec 2012
    thanx will get a good look about it tomorrow or early monday morning main 80am definitely ok
    genius76's Avatar
    Dec 2012
    Lowestoft
    Quote Originally Posted by gazvts View Post
    my case was +12 feeding problems on abs but u know That always check first
    That maybe helps anyway
    ALLDATAdiy.com - 2009 Nissan-Datsun Altima V6-3.5L (VQ35DE) - Computers/Control - CAN Code, Diagnostic Tips/Guidelines
    Aug 2010
    Zibo Shandong China
    Seen similar thing on an Audi
    Poor connector block into abs pump
    Multiple faults like speedo and other faults
    Faulty pins in connector block to abs pump
    Possibly corroded?
    Let us know the out come?!
    DK Veteran rashid01's Avatar
    UAE
    take out all connecter from all ecu then check agine
    Dec 2012
    thanks guys
    genius76 thanks for that
    all fuses checked yesterday when i had 5 mins so i will be going through all connections an wiring first thing in the morning
    Nov 2023
    Sorry by reviving this old topic, but it is better to write on existing one than creating 1000 of same issue..
    Would love to know if the issue he fixed? I have nearly same situation, but little bit toughter...
    While car has ERRORS on ABS brakes RED and ABS, - commutations between all modules (except ENGINE and AIRBAGS) are gone. Can't read any codes or do live data. Speedometer doesn't work, all units looks like working. Today turned car on and ABS light gone, so instantly checked the codes are stored, and found communication related trouble codes. Anyone can help me? Can't find anywhere the CAN commucation line scheme, where it is located, wanna check wires there. Also Once everything get back to working, it stops after first brake pedal press on snow (with a little slide), ABS turns back ON red STOP also, commucation lost again between all modules expect Engine and Airbags.
    Anyone can help me out? It is Wife's car, and during winter I must ensure her safety drive.
    NISSAN MICRA K12 2004 1.5dCI 48KW
