    Default mercedes w211 seat belt pretensioners bypass
    hi
    can i use the resister trick to make the srs light go out?
    the problem is the front drivers seatbelt it seems to work by but throws the code seat belt squib resistance too high?
    the seat belt unit has many wires connected to it where does the resister go?
    check picture
    genius76's Avatar
    Dec 2012
    Lowestoft
    Any more codes or same not working equipment?
    I can help you but only if you want me to help you
    All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
    alclot's Avatar
    Melee Island
    Hi everybody. Did you fix it that problem? What resistance do you put?
    Thanks in advance
    Jun 2009
    also interested in knowing this
    2.2oms work
  6. The Following User Says Thank You to ford2002 For This Useful Post:
    sol-1 (20th April, 2019)
    Oct 2018
    egypt
    disconnect connector and use 2.2 ohm resistor ... or disconnect connector and code airbag unit without required zunkreis (in development read code in german and disable)
    wbr.
  8. The Following User Says Thank You to hesham10 For This Useful Post:
