Results 1 to 8 of 8
    DK Veteran VTS_Tibi's Avatar
    Default INPA cable with Carsoft / BMW Scanner
    Hi Guys,
    As my normal INPA K+CAN cable died I'm about to buy a newer D+CAN cable.
    BMW INPA K+CAN
    Could I use this cable with the BMW Scanner 1.4.0 and 2.1.0 software, or do these need a different cable? As if I can not, I'll just simply buy this interface:
    Super BMW INPA +140+2.01+2.10 Diagnostic Interface
    Which incorporates an INPA D+CAN / BMW Scanner 1.4.0 and 2.1.0 interface.
    Thanks,
    Tibi
    dave11674's Avatar
    Florida, UK
    hi mate did you buy these tools ?
    if so how did they run ?
    do they do what they say they can do ?
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    Smok PSA, volvo & ford
    If someone helps you DONT FORGET TO SAY THANKS its only polite....
    smokey08's Avatar
    Essex, UK
    What 1 are you intrested in dave?
    K+Dcan is a very very good cable if you buy it from the right place. Everyone says to buy it from onestopelectronics but the one I have is from cable-shack and funtions flawlessly. I have used it with DIS, INPA, flashed modules with winkfp, coded modules with ncsexpert and never ever had a problem. It lives in the boot of my car and gets used probably more than the ICOM I have at the workshop.
    I originally brought a bad 1 from china a long time ago and it wouldnt work with post 2007 can-bus cars so choose carefully where you buy it from. I have the ?37.99 version with the block that joins pins 7+8 for pre can cars.
    Here are some screenshots from a r56 mini and from an e46 M3 that I used my cable on.
    The software that came with the cable was crap. I installed it my own way to get it exactly how I wanted it.
  4. The Following User Says Thank You to smokey08 For This Useful Post:
    dave11674 (20th August, 2013)
    dave11674's Avatar
    Florida, UK
    hi mate thanks for the response
    i was thinking about getting this..
    4 in 1 BMW Diagnostic Interface
    im basically wanting to code used units into ....2010 cars pre F series
    change coding, matching vins etc etc
    dave
    Tools owned.
    AVDI commander.
    Dashfixer orig.
    Dashfixer clone.
    Fiat km tool.
    Opel km tool.
    Ford KM tool.
    Op--com colne.
    Lexia & PP clone.
    and does the d+can cable work with bmw scanner software?
    br.
    smokey08's Avatar
    Essex, UK
    Quote Originally Posted by dave11674 View Post
    dave
    I have not tried that interface but I have used bmwscanner 1.4.0 and it makes it very easy to change vin but its limited on coding. If it does what it says it would be a good choce as you could run ncsexpert with it to change vins and for advanced coding.
    sepistar the k+dcan cable will not run bmwscanner software.
  8. The Following User Says Thank You to smokey08 For This Useful Post:
    sepistar (25th August, 2013)
  9. #7
    wich sw.did you use with this tool?i use carsoft and inpa.but if there are another sw.please let me know.
    br.
  10. #8
    Aug 2013
    no it doesnt
