Results 1 to 13 of 13
    darwins's Avatar
    UK
    Default 1996 Ford Scorpio 2.9 pats box ?
    1996 Scorpio 2.9 Auto
    Engine ECU EEC1V
    90GB-12A650-HB
    Tear Tag: 0GHB
    Hello Friends
    Can anyone help with where the immo box is fitted on a 1996 Ford Scorpio 2.9 Auto ?
    Any info about the immo system on this old bus would be useful.
    Thanks Guys
    Darwins
    Go for it. The future is promised to no one
    antonypaul's Avatar
    Default hello
    Dear Friend,
    Hi Attached image of Ecu of Ford Scorpio it same type of your car ?
    We live and work in a changing world. New laws are introduced that lead to the introduction of new policies.
    darwins's Avatar
    UK
    Yes this is the same PCM...
    I'm thinking this will have a pats module somewhere, I have limited info on this system and can not see the immobiliser linked to the PCM.
    Any info would be great, Immo Off would be best if it is possible..
    If not I have 3 keys including a red master but the car is not to hand, As I understand the keys will not program in the normal way for some reason.
    Darwins
    DK Veteran cleevesy's Avatar
    Check left and right kick panels , theres a couple of immo offs on here whats the part number of the ecu? eev?? something?
    darwins's Avatar
    UK
    Here is the ecu part numbers it's EEC1V
    think i found an immo off for that ecu does it have a tms chip on the board? something about taking it off and joining pin 2 to 6 i think il see if i can find it
    heres link
    http://www.digital-kaos.co.uk/forums...eec-iv-111194/
    Pats unit is on bulkhead on right (drivers rhd) side of heater box above clutch pedal and to left. Take full top off dash so you can see a bit better.
    all wires to it are black, wasnt made to be removed easy.
    I dont think the pats is linked to the pcm, i seem to remember the power to the injectors, pump and coil run through it.
    Good Luck
    darwins's Avatar
    UK
    Thanks cleevesy pianoman58..
    The ecu is different to all on DK, I think pianoman58 is right about the pats having control of fuel & ignition, I will take another look into this in the next few days..
    Meat-Head's Avatar
    I would like to SPAM this thread as well please.
    Firstly pop here and look at this foto
    Ford Probe Immobiliser with 2 Remotes | eBay
    then carry on.
    1) see if the key has a transponder 4C first (don't think so)
    2) Look on the sppedo meter see if on the flat trim is a red led that is on solid?
    3) If red led which is solid, grab a pry bar, cheisel or punch.
    remove the radio, then you will see the unit, simply remove the unit by <CLASSIFED INFORMATION> You will need some new swear words, so keep a pen and paper handy.
    Once you have go it in your hands, undow the four screws, discard 3 of them.
    Right, once inside you see 3 relays laughing at you, resolder ALL of them
    then you see in the middle looking smug grinning like a cheshire cat is a transiser, grab your favorite soldering iron, say out loud
    "EAT LEAD PAL" - blob all three legs with solder (you only need the right two - but you need to show it who is boss).
    then using the one remaning screw put the lid back on, think theres a metal bracket, not sure - buth either way it will look great in the bin.
    3) If it has a 4C transponder then sorry can't help
    4) If your sad enough to want to add new remote if you do - then
    then google 'ford pube add remote' you know when you find the right info it says something like
    stand on one leg wait ten mins
    cycle ignition
    stand on other leg for ten mins
    takes a genuine 1/2 hr to add remotes, false move game over, disqualified back to the pits.
    darwins's Avatar
    UK
    This car has an unmarked plastic box (PATS Box) near the ecu behind glove box wires are colour coded not all black...
    All 3 keys are 100% matched to pats box.
    Anyone have a wire diagram?
    Meat-Head's Avatar
    How does no grab you
    Anychance of photo or part number
    Transponder keys?
    darwins's Avatar
    UK
    Hello Meat all the info is in the first 2 posts
    I reckon the info for this car must be in paper form because even though the car is listed on the early Ford TIS 2000 - 2004 CD their is nothing for selection
    As far as Grab goes good idea..... I'm going to grab a bacon butty
  13. #13
    Meat-Head's Avatar
    cool, understand suggest yunking out the PCM relay and
    1) replace with new 2) link out
    beleive there was a thread where relay was dropping voltage
    try asking Justy22 for some timps with jumpleads to up the voltage
