Results 1 to 8 of 8
    Default vauxhall astra h
    07 reg, problem i have is electric convertible roof. was put down and as never came back up. i find some broken wires which were repaired but still will not work. it seems to have stopped in a position were it is neither closed or opened, is there a reset for the roof. i look on tech 2 but no programming for roof. when i press button there is just a slight click and nothing else. no faults stored in roof controller. pull mat is across in boot, can anyone help. thanks
    Meat-Head's Avatar
    If its a hard top start crying
    Sorry on phone in bed searcgh for some inferior wiki opel site or something but the tigra commom fault the motors lh and rh microsewitches gonintermitttan
    Keep thisvthread updateded
    DK Veteran Larue's Avatar
    Somerset, UK
    If you have Tech2 then you should see in actual values something wrong.
    Can't do actuator tests as well?
    with tech 2 all you can see is actual microswitches/sensors, there is no actuator tests, this is the hardtop, twintop. thanks
    Meat-Head's Avatar
    Well look for
    Left lock. Active
    Right lock. Inactive
    Keft motor unlock. Active
    Right motor unlock active
    See if you can find a fifference one
    Hate ipjone its crap
    Aug 2011
    Spalding
    This is live data from a good with no faults roof:
    Measuring blocks information:
    Hardtop Switch Inactive
    Hardtop Remote Control Status Inactive
    All Window Lifter Status Inactive
    All Window Lifter Remote Control Status Inactive
    Easy Pack Switch Status Inactive
    'Hardtop Closed' Contact Switch Status Active
    Frame Contact Switch Status Active
    Front Latch Contact Switch Status Active
    Easy Pack Contact Switch Status Inactive
    Trunk Lid Latch Contact Switch Status Closed
    Parcel Shelf Sensor Status Up
    Front Trunk Lid Sensor Status Inactive
    Trunk Lid Contact Switch Status Inactive
    'Hardtop Open' Sensor Status Inactive
    Luggage Protection Status Active
    Have a look at yours and compare.
    Normally theres three wires on the left hand wiring loom inside the boot that break.
  7. The Following 3 Users Say Thank You to MJRVR For This Useful Post:
    cole_mcs (25th June, 2020), dziongas (17th July, 2019), Eddie034 (24th February, 2020)
    Meat-Head's Avatar
    Did you sort this, got a pub quiz to write thought would be a good subject
    Meat
    Nov 2017
    Does somebody knows where this "Frame Contact Switch" is positioned on car? Fix all other problems but this one is real pain. No fault code just wrong value not active instead active.
