Results 1 to 13 of 13
    Oct 2012
    Default Toyota Avensis 2009 T27 Electronic Parking Brake fault
    I have toyota Avensis 2009 T27 with Electronic Parking Brake fault (water inside module). After replace EPB module (used ) parking brake began to work ,but I still have warnings on IPC. I check DTC and I have C1203 Vehicle information mismatch in EPB module. I have Techstream. What I should do after replace EPB module (used ).? Thx.
  2. The Following User Says Thank You to Adask83 For This Useful Post:
    DjRomeoR (5th November, 2013)
  3. #2
    miha99's Avatar
    EU
    Only gues.... maybe you should swap memory from replaced module to new one.
  4. The Following User Says Thank You to miha99 For This Useful Post:
  5. #3
    genius76's Avatar
    Dec 2012
    Lowestoft
    Hi mate i found that need some do learning after any disconnecting or something
    but maybe it helps
    I can help you but only if you want me to help you
    All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
  6. The Following 3 Users Say Thank You to genius76 For This Useful Post:
    attila803 (21st December, 2019), DjRomeoR (5th November, 2013), jmac200t (1st April, 2021)
  7. #4
    Oct 2012
    I will have car in tuesday so i will try do learning procedure. I will report result. ps change eeprom it is really last solution, because this module is difficult to open.
  8. The Following User Says Thank You to Adask83 For This Useful Post:
  9. #5
    Lexas's Avatar
    where is report? what is learning procedure and did it help?
    Don't Forget Button
  10. #6
    dimitar's Avatar
    Your VIN mismatch
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  11. #7
    Oct 2015
    Waiting for that report too?
  12. #8
    Mar 2013
    Guys i have customer who has an avensis that has already had a used epb unit fitted and at a guess he has a vin mismatch too
    The old original unit is not available ,has anyone opened these to see if it has an eeprom memory inside that might holda vin number ?
  13. #9
    Yes has eeprom inside don't remember type.
  14. #10
    DK Veteran JIMMYQ's Avatar
    Mar 2008
    anyway to read these units ie pinouts or what tool instead of opening to find eeprom?
  15. #11
    Aug 2020
    Witam posiadam avensis rok 2010 taki blad toyota C13A7 Awaria siłownika czy ktos z was wie jak to naprawic ?Zaciski nowe,klocki nowe,reczny dziala wlacz /wylacz ale swieci sie kontrolka .
  16. #12
    Mar 2021
    Polska
    Default yoyota t27
    witam koledzy pamięć w module to 95160w
    to nie vin to kodowanie auta np. Automatyczna skrzynia biegów czy manual i wiele innych ustawieńTak,
  17. #13
    Mar 2021
    Polska
    cześć koledzy
    Pamięć w module to 95160w
    to nie vin, to dane kodowania auta np. automatyczna skrzynia biegów czy manual i wiele innych ustawień
