Hi.
Wow can i program new remote to Suzuki Ignis 2007 ?
I have try procedure from Grand Vitara but not working.
Hi.
Try this
Procedure
1. Confirm that IG switch is OFF position.
2. Remove DOOR LOCK fuse and install it again.
3. Press the button on the remote one time toward the receiver within 30 sec
4. If two transmitters are registered, repeat step 1) to 3) with other remotes
Notes
: a. Two transmitter codes can be registered.
b. When a 3rd/new remote is registered, the oldest one will be cleared
not working for me![]()
Can you post a picture of your key fob?
try this
IGNIS 2000-2006
WAGON R + 2000-2008
1 Make sure the ignition is OFF and all doors are closed
2 Open the driver's door and turn the ignition switch to the ON position
3 Within 10 seconds of turning the ignition, switch to OFF and remove the key
4 Within 20 seconds of turning the ignition switch to OFF, hold, and release the button 3 times on the driver's door
5 Within 10 seconds after you release the button on the door, turn the ignition switch to ON, then OFF
and remove the key
6 Within 10 seconds, press the open button
7 The programming procedure is complete
8 Car opening and closing the system will indicate the correct program
Note: Maximum 3 remotes can be programmed
JOSEPH1975 (24th May, 2024)
Try the following procedure.
https://www.dropbox.com/s/9v23laky9i...0procedure.pdf
kyawkyaw (18th April, 2016)
I did one like this last week- ther is something about open and close doors 3 times
נשלח מה iPhone שלי ע"י Tapatalk
You are the man![]()
