Results 1 to 7 of 7
    Default Info for Vauxhall Combo speed limiter setting
    2006 Vauxhall Combo diesel. Ex Royal Mail van. Owner claims that it's limited to 70mph and wants this removed. I had a look with OpCom but can't see any speed settings. Does anyone know if you can restrict max speed on these and if so can Opcom access this setting to switch it off.
    Thanks.
    Meat-Head's Avatar
    look under the dashboard for something that does not look like a block of cheese.
    DK Veteran Larue's Avatar
    Somerset, UK
    Quote Originally Posted by BRAVO6 View Post
    Thanks.
    You can do that by reprogramming with TECH2. There are different software versions with or without speed limiter.
    Sorry, not good at solving cryptic clues.
    Meat-Head's Avatar
    Would this be in the thrunk or under the dashboard?
    Does it look like a block of cheese?
    New Genuine VW Caddy 120Kph Speed Limiter by VDO ZGB2K0052905 | eBay
    Aha!. Didn't even look. Owner reckons it's done through ECU with no extra bits. Do you think it might have added little box?
    Feb 2013
    UK Bristol
    I know topic is little bit old... (6 years ;-p)
    but have the same job to do it.
    owner said car is after British gas and drive just max 70mpg.
    I send file (map ECU) to do it my tuner but he told me VMAX (Speed Limit) is not ic ECU, i check all setings via OPCOM but cant find anything about speed in all modules.
    Any advice?
    My post helps you? Please Hit Buttons
