Results 1 to 15 of 19
    Mar 2009
    Default P1723 on opel astra h
    hi
    i got P1723 when reading gerbox control module, car won't start and displays F on dashboard.
    Can somebody share a solution regarding this problem?
    regerds.
    Above sea-level
    Probably an easytronic?
    Could be a locked shifting mechanism or weak motor.
    Just remove it and check if still can move properly.
    Mar 2009
    yes easytronic, but p1723 refer to a gear selector problem,not?
    electrones's Avatar
    Feb 2012
    Around C.V
    Quote Originally Posted by gccb View Post
    Hi friend
    CHecks the main control relay transmission is ok
    good luck
    NONONONO trust me! i replaced A lot of these ! camshaft or cranckshaft sensor 100% that one of them is Dead. this is a tipical Opel fault with easytronic.
    Trust me you will thank me
    Meat-Head's Avatar
    What is battery goltage at?
    Mar 2009
    hi
    thanks for your answers, i think it's not a camshaft or crankshaft problem, i read engine memory and thre is one fault "check gear box" starter is not running because blocked by ecm, voltage is ok,got the famous p1723-08 activeselect tip switches signal range/performance.
    any help?
    I got the samee...starter wouldnt turn..and wash cranck or camshaft sensor..i believe crank..just google a bit.
    Mar 2009
    have you got P1723 as fault code??
    Oct 2012
    you need to adapt the parameters of gearbox, i belive you can do with op-com
    genius76's Avatar
    Dec 2012
    Lowestoft
    Hope it is helps for understand
    And always don't forget brushes on clutch motor
    I can help you but only if you want me to help you
    All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
  12. The Following User Says Thank You to genius76 For This Useful Post:
    Shan (4th November, 2024)
  13. #12
    skrubal's Avatar
    Apr 2013
    Bulgaria
    genius76 is right for brushes motor of the clutch then adjust the gear selector to the middle position and drop in adaptation op-com.
  14. The Following 2 Users Say Thank You to skrubal For This Useful Post:
    genius76 (1st July, 2013), Meat-Head (1st July, 2013)
  15. #13
    Mar 2009
    still have big problem with this car which refuses to start, when i try to adapt gear parameters with opcom all ok opcom ask me to jack up the car and hold brake and start then i got starter on for 1s and cuts and lose communication with engine ecu , ihave to disconnect and reconnect battery to communicate with engine management.
    please help me on this strange story
  16. #14
    Meat-Head's Avatar
    Well looking at the date this thread was started and the date now, and the number of your downloads and number of thanks, using a corrupt copy of brain.exe data comes back to say
    "short the self starter with a potato fork" Report back
  17. #15
    genius76's Avatar
    Dec 2012
    Lowestoft
    On my words try to disconnect starter when fid up him from another er source when start engine possible somewhere you get short that under loud voltage when spin starter occurs, or if after reconnect battery tray put some battery checker with starter loud improviser when se what happens possible if somewhere bad contact or minus you ecu again cuts off so if u not get again communication you know that bad minus or feed contacts
  18. The Following User Says Thank You to genius76 For This Useful Post:
    Meat-Head (27th October, 2013)
