if ftdi ic is recognized by windows, that is, if you can install drivers, but the interface doesnt work (test in vag-com 3.11 or 409.1 or vcds-lite) then lm339 smd ic is broken
this is a common problem, lm339 burns very often...
you can buy in local dealer (0.30euro) or ebay (10x 1.80usd)
remove it with the help of two soldering irons: solder all pins together in both rows of 7 pins and then heat both rows, the ic will easily separate
then solder the new ic: position the ic, solder 4 pins in the corners so that it doesnt move, and then the full ic
im waiting for new lm339 to arrive and then will try
edit 16th april 2013:
today i received the 10x lm339, i soldered one and interface is working perfect, only some cents to repair
with the flux it is very easy to solder this ic
this confirms that lm339 is the problem, which usually burns out, it's just as easy as replace it
