Hi. Am attempting to program a key for a VW Golf 1998, Immo 2 using SBB. I was able to extract the pin code from the instrument cluster to program a key. This car according to the year can use either ID33 or ID48. I have tried programming a VAG ID33 chip which failed. The problem I have is that I do not have ID48 chips pre programmed for VAG cars. I do have blank Megamos 48 chips. Is it possible to precode the chips myself as there are no local suppliers of pre programmed VAG ID48 chips. I have Zedbull. Thanks.
