initally when you load dream up, do you choose com1 or two from the drop down or do you leave them do you tick the box marked " used network"?
do you have to put the ip addresses in?
You use which ever suits your needs. Most PCs only have one com port so select com1.
If you are only using a null modem cable then don't check the 'use network' box.
hi ive got a dreambox but i do not know how to fix it as it has gone it keeps on saying service could not be found this hppend after the keys rolled can u show me how to fix it or is there an easy way of doing it . also do u have to connect the dreambox to ur computer and ur TV simultaneously to flash it. and can u use a trial version of smartFTP of do u have to get a full license for it to work.THNX
Sorry. but i also heard about autoupdating keys and stuff like tat does tat mean tat the box will not go out ever again.
Follow the instructions in this thread and you should be fine
http://www.digital-kaos.co.uk/forums...ead.php?t=1273
Trial version of smartftp will still work for a limited period, or you could use a free client like filezilla.
ty ... I got a serial cable which does not work. I'll try it with modem cable tomoroow
i have flashed the drive with dw 2.0. but all i get a a boot screen, it asked for time zone and then, back to boot screen and nothing happens.
any help lads would be appreciated.
read booted it and now scanning. thanks lads.
need help. have manual scanned box, and all channels have come up, but only the free to view channels are showing. i have used digital world 2.0.
what have i done wrong. i scanned with bruteforce as i live in england.
any help would be very much appreciated.
Go to a premium channel and press Blue then OK.
were can i get null modem cable from for my dm500c so i can flash it
