Results 1 to 15 of 19
    Mar 2009
    Default Bmw E90 320i engine N46B20BA misfire issues
    Hello Guys.
    I am working on this vehicle.The car had misfire fault.I had cleared the fault codes(the misfire went away) and then fitted in 2 good coils that I had in stock to cylinders 3 and 4.Took it for a drive and re-read the fault codes. and this is what comes up
    1. 2C24 O2 SENSOR (BANK 1, SENSOR 1 AND BANK 2, SENSOR 1) INTERCHANGED
    2. 29CC COMBUSTION FAILURE ,
    MULTIPLE CYLINDERS DETECTED
    3. 29D0 COMBUSTION FAILURE : CYLINDER 4 DETECTED
    4. 29CD COMBUSTION FAILURE : CYLINDER 1 DETECTED
    5. 29CE COMBUSTION FAILURE : CYLINDER 2 DETECTED
    6. 29CF COMBUSTION FAILURE : CYLINDER 3 DETECTED
    7. 2E27 IGNITION COIL, CYLINDER 4 FAULTY
    Thanks guys
    Feb 2012
    Greece
    this might not be coil problem but spark plugs, did you replace spark plugs as well?
    whats is the mileage? these spark plugs tend to fail after 100K km from my experience.
    you have to fit exact same coil and no other that "look the same" on this car.
    Mar 2009
    spark plugs are new
    eliasole's Avatar
    Look intake for leaking and loose under pressure.
    eliasole's Avatar
    or the maf.....
    Mar 2009
    I will fit in a new maf and see what happens.
    Feb 2012
    Greece
    what's the reading of current MAF on data?
    genius76's Avatar
    Dec 2012
    Lowestoft
    on oldest 532 and similar be problems with pressure if you checked all electronics and 100% lambda sensor are correct - check pressure in cylinders
    I can help you but only if you want me to help you
    All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
    I have known this engine to jump timing chain if it backfires, check valve timing has not altered as a result of missfire also check engine breather system pipes are clear & no air leaks have occurred.
  10. The Following User Says Thank You to mtechno For This Useful Post:
    bonecrusher (8th April, 2013)
  11. #10
    Netherlands
    Timing chain is indeed a trouble maker but when worn or jumped usually ecu throws also cam sensor fault.
    Check the crankcase breather below the inlet manifold, simple test is to open the oil filler cap when engine running, if it nearly stalls the breather valve unit is broken.
  12. The Following 2 Users Say Thank You to easytech For This Useful Post:
    bonecrusher (8th April, 2013), teerak2uk (29th June, 2019)
  13. #11
    Mar 2009
    I have checked the crank breather it is ok. I have installed 2x new original oxygen sensors before cat, 4 x new coils and plugs and yet I still have the same faults.
  14. #12
    smokey08's Avatar
    Essex, UK
    Looks like the pre cat oxygen sensor connectors are connected wrong. Swap the connectors with each other and try it again. I suspect they are lean misfires where the sensors are adjusting the wrong cylinders.
  15. #13
    DK Veteran the_riddler's Avatar
    Jun 2009
    In The Workshop Or At The Pc
    Agree with above
    sounds like 1 off the faults is wrongly connected sensors.
    happens alot on head work when tech does not lable connectors, whilst removing
    but not seen those other faults at same time before....
    but hey we learn new stuff by the day...
    Still in the workshop.
    if this post was use full
    please press
    the thanks button
  16. #14
    Mar 2009
    Thanks for the tip, will update soon as it is fixed
  17. #15
    Mar 2009
    never got to fix this car. The customer and I were tired of putting money into the car. I advised him to take it to someone with more knowledge
