Results 1 to 11 of 11
    Sep 2012
    Default gm tech 2 for key programming
    good day members...
    i purchases a used gm tech2 with isuzu card. how ever when i try ptogramming transponder it says "approval from tis required". i have pc software as well. can someone who has this tool please explain to me the process of retrieving this approval ?
    thank yu
    leandroks's Avatar
    Brazil
    Buy another card from china and i ll be able to do that...
  3. The Following User Says Thank You to leandroks For This Useful Post:
    MonSter911 (12th April, 2013)
    westville locksmiths's Avatar
    Sep 2011
    South Africa.
    No, another card wont work. Use old card get Tis approval , internet connection ....
  5. The Following User Says Thank You to westville locksmiths For This Useful Post:
  6. #4
    May 2011
    u need to have tis on your laptop
    connect your tech2 to a laptop and then get tis approval
    or u can buy a subscription online
    anyway to program ecus or keys with tech2 u need
    tech2 unit
    old school laptop with d9 serial port or good usb to serial adapter
    tis software
  7. The Following User Says Thank You to sideshow For This Useful Post:
  8. #5
    Sep 2012
    thanx for the reply. i will try tis software annd see if that works.
  9. #6
    Sep 2012
    hello members
    i cant get this tool to connect to pc tried connecting it to 3 pc. i think because it is china cone. perhaps purchasing an already tis approved isuzu/opel card ?
  10. #7
    May 2011
    I've got tech 2 clone and proper tis software and it works fine
    u need good USB to serial adapter
    its all in the settngs
    took me a week to get it all working fine
    plus u need software on your tech 2 card to suit the vehicle
    its not a plug and work system u need to play around abit
  11. The Following User Says Thank You to sideshow For This Useful Post:
    MonSter911 (16th April, 2013)
  12. #8
    May 2011
    In tis first goto screen that shows tech2 screen on pc
    then connect and disconnect
    then try tis approval. It's all trial and error
    just remember tis is the worst and most unstable software out there heheh
  13. The Following User Says Thank You to sideshow For This Useful Post:
  14. #9
    ahadi's Avatar
    you just need pin code , i did isuzu trooper with tech2 isuzu card no problem.
  15. The Following 2 Users Say Thank You to ahadi For This Useful Post:
  16. #10
    DK Veteran teuton's Avatar
    Mexico
    with a proprly installed tis on your lap and the usb/seriel converter you should open "security access" on the main screen on tis, and go on from there. As sideshow said it's a bit tricky to configure the system settings, but it's all there.
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
  17. The Following User Says Thank You to teuton For This Useful Post:
  18. #11
    Sep 2012
    thank you very much friends... all this info gives me piece of mind that i wasnt ripped off completely....
    i downloaded new tis software via a torrent. so i am playing around wirth this to try and get it to work.
    i tried security access but the "connecting to server screen" comes up and stays on.
    please note that i do not have any dongle or anything for software. jus tech 2, adapters and opel and isuzu card as well as rj45 cable.
    i will keep trying.
