Results 1 to 4 of 4
    Default What will read SAK XC164CS ?
    trying to find some spare time to play with the Modus / Clio Steering columns.
    I have stripped a later (09 car) column and found SAK XC164CS 32F40F along with 24LC16
    I would like to read the SAK XC164CS 32F40F what will do it easily?
    I am working on a hunch that the micro also logs the fault code "def1"
    The "def2" fault code seems to clear via the eeprom but I couldn't clear "def1" via eeprom dump.
    I am fitting this between jobs etc.
    many thanks
    Quote Originally Posted by albertros View Post
    Using minimon soft in boot-mode via serial port of XC164CS.
  3. The Following User Says Thank You to veloseeped For This Useful Post:
    albertros (24th April, 2013)
    many thanks. Just get my head round connecting to rs232.
    I use interface like in attached pdf
    Universal variant - easy configurable for various tasks and CPUs.
  6. The Following User Says Thank You to veloseeped For This Useful Post:
    albertros (20th November, 2013)
