Results 1 to 15 of 23
    May 2013
    Post Autocom CDP Pro not connect in vehicle
    Hi guys, I need help with a CDP Pro Bluetooth.
    He does not connect in any vehicle, already tried using versions 2011.3, 2012.2, 2012.3 and 2013.1, and none of them worked.
    Firmware upgrade and Test OK, normal functioning but still does not connect in any vehicle.
    I tried on:
    Fiat - Palio
    Fiat - Uno
    Renault - Master 3
    Any idea?
    And tried with CDP + these cars and it worked.
    Thanks for help
    Dec 2012
    check the pcb for bad connections/solder or missing parts
  3. The Following User Says Thank You to gazvts For This Useful Post:
    dopsleutel13 (22nd October, 2013)
    Dec 2012
    bulgaria
    has exchanged pins cable. check
    Dec 2012
    bulgaria
    okie or missing chip tester.problem auto com
    May 2013
    Quote Originally Posted by svetlin09 View Post
    Cable OK.
    OKIE Chip OK.
    Chip Teste?
    I will check if it has no sloppy soldering.
    Oki chip is for pwm ford protocol.
    You have problem with k-line.
    You must test on can bus car too.
    Dupnitza, Bulgaria
    I have the same problem with CDP+ (new VCI- single board) and delphi 2013.1. Interface doesn't connect with ABS module in 16pin OBD, but via k-line 2pin socket connection is perfect. I'm looking for circuit or already known fixed bugs. I checked interface for cold junctions, found nothing.
    Dec 2012
    software or try upgrade license only on delphi
    Brand: Delphi
    Software: Cars
    Version: 2.13.1
    Serial: 100251
    Key(s):
    DieselMax : LBDLPTSVHNIM
    GWM : ERCKKCNTESAS
    GWM_MAX : EJZBPOTXOCWD
    HardwareKey : OUQFPFEBUHBK
    MaxModule : KNJSIQQBPEHP
    TurboCharger: GDFUTFDHXGIP
  10. #9
    Dupnitza, Bulgaria
    Hi gazvts, I enclose picture of my license view. I don't think there is something unusually.
    Best regards!
  11. #10
    Dec 2012
    maroc
    Autocom CDP Pro se conecta en el veh?culo
  12. #11
    Oct 2013
    GB
    hola,mi interface de autocom se queda con la luz roja cuando lo conecto al ordenador y no me funciona el programa
    por favor ayudarmeeeee,muchas graciasss
  13. #12
    dopsleutel13's Avatar
    Dutch
    Quote Originally Posted by aprilia40 View Post
    You must also connecting to the car
  14. #13
    I have the same problem with CDP+ (new VCI) and delphi 2013.1. Interface doesn't connect with VW Crafter.
    VW Sharan -worked.
    Ford Galaxy -worked.
    normal functioning but still does not connect in any vehicle!
    What to do?
  15. #14
    Dutch
    Quote Originally Posted by PacMar View Post
    VW Sharan -worked.
    What to do?
    crafter should work from year 2006 , even generic eobd 2.5 engine common rail .
    sometimes disconnect hardware from car and usb and try again wil help sometimes ..
  16. #15
    jakesman's Avatar
    Oct 2013
    Bethlehem Southafrica
    hi all
    have the same problem with Autocom CDP with OKI chip was sold with VER 2011.1
    VER 2011.3.5 read all modules on CRAFTER
    VER 2012.3 read all modules but not engine ECU (2.5l) on new crafter 2.0l amarok engine it is fine but not read the ABS
    VER 2013.1 do the same as 2012.3
    Firmware updates work fine no problem there
    ANY IDEAS ?
