Results 1 to 15 of 18
    Jun 2011
    near bigest capacitor
    Default Launch x431 diagun bluetooth problem
    Dear guy i have a diagun x431 but bluetooth is not working.with cable its working.Also i tried smartbox with another diagun its working.Problem is in main unit.
    But i want to know its hardware fealure or software?i changed memory cards with another diagun but problem was still there.
    Do you have any sollution and where is bluetooth settings on main unit?
    miha99's Avatar
    EU
    Most common problem in main unit bluetooth hardware.
    Jun 2011
    any specific solution?which ic or can we change this module?
    DK Veteran NZBrakelathes's Avatar
    Aug 2010
    Zibo Shandong China
    I once price the Bluetooth Module in smartbox
    If yours is a copy fake unit then there common to fail as its not made at Laynch factory
    Jun 2011
    And What about sollution?
    Aug 2010
    Zibo Shandong China
    Quote Originally Posted by cagatay87 View Post
    I can only suggest buying replacement module
    Pm for seller that might still have one
    NZBRAKELATHES is right.the problem must be from diagun main unit bluetooth module.the best solution would be changing the module from main unit.
    Jun 2011
    may i use another bluetooth module from chineese tables? anyone know connection diagram?
    DK Veteran sergej's Avatar
    Latvia,Riga
    Reset BT module -in setting tap <-->.
    5V in BT module?
    Change 2 SP3232 (MAX3232)-first in motherboard =U19 ,second in BT module.
  10. The Following 6 Users Say Thank You to sergej For This Useful Post:
    cagatay87 (8th May, 2013), clotza (9th July, 2019), Darkangel25 (25th July, 2019), gorgamin (21st June, 2016), paro44 (13th May, 2013), pilotby (21st February, 2018)
  11. #10
    Jun 2011
    Quote Originally Posted by sergej View Post
    5V in BT module?
    this is answer that i want thank you dude
  12. #11
    Aug 2010
    Zibo Shandong China
    Did this reset solve your issue ?
  13. #12
    Jun 2011
    Quote Originally Posted by NZBrakelathes View Post
    yes it solved.without any ic change it solved my problem...
  14. #13
    Aug 2010
    Zibo Shandong China
    Cool!
    But how was it done? I couldn't make it out how it's done?
    Just reconnect via PDA? Or thru the wires of ic chip??
  15. #14
    Jun 2011
    Cool!
    i connect smartbox to a car and i opened pda.***304; clicked bluetooth icon and settings there is a <-> button as a picture.wait until its done.
    Enjoy...
  16. The Following User Says Thank You to cagatay87 For This Useful Post:
  17. #15
    Jun 2016
    South Africa
    Hi Sergei, I've gone through the Diagun there is 5V present to the MAX3232 v+ pin, and the Module gets a stable led after performing reset, but smartBox won't connect.
    Should I replace both MAX3232 chips?
    Which one (for example U19) is it in the module?
    Also, I see yours has two wires running from the chip, what is that for?
