Results 1 to 12 of 12
    Member giggsy07's Avatar
    Nov 2008
    Unhappy vag com 409-1 urgent help please
    Hi guys hows all.Like the headline says im lookin for urgent help wit vag.Have the crack and used it.vag tells me its registered and then goes back to shareware wen i plug it in.Iv read thru the other posts guys and sorry im not totally understandin it all.any easy explanation would greatly be appreciated..Thank you..
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Jan 2009
    usually when the icon saying this requires vag to be registered appears, i go back one stage, resend crack files, [dont go back to start or it wil un register it self again as u go forward] i usually have crack files on desktop as i may need to send them a few times ,
    Nov 2008
    Quote Originally Posted by david916 View Post
    Hi man.just to clarify are you using the vag com update program crack yes?so wen vag tells me it needs to be regeistered i just run the update program again?Thanks again...
    Mar 2009
    tried rebooting?
    Nov 2008
    Quote Originally Posted by crocket2k View Post
    tried rebooting?
    Tried everythin mate...
    Sep 2010
    I have the issue too
    Top Poster Furax's Avatar
    Manchester
    There was a nice copy on here that you just had a loader to run it. Try find that?
    I can fix that for you no problems, just let me find my good hammer..
    hi having the same problem.
    tried going to the link but only get a login page
    Oct 2010
    Smile
    Quote Originally Posted by giggsy07 View Post
    I have a versions that works. with USB link connector.
    Just copy file content in C
    Default VAG-COM 409.1 goes back to unregistered
    Anybody has a soluction for this? It keeps going back to unregistered.
    dopsleutel13's Avatar
    Dutch
    I had the same problem with Vagcom 409-s and the loader was blocked by the antivirus-software even ZoneAlarm was blokking the loader .
    I turn it off and vacom worked fine for me again.
    maybe this will help for you too .
