Results 1 to 12 of 12
    GB
    Default Toyota Corolla Lost all keys
    Ecu 89661-12E81
    I need an immo off solution or virgin file to start car.
    Eeprom has RH56 written onto it.
    Thankful & Appreciated
    achaccha's Avatar
    Nov 2010
    Ecu 89661 - 12E81 is a vehicle without immobilizer.
    you can post your VIN number please
    regards
    GB
    Quote Originally Posted by achaccha View Post
    regards
    It has got an immo .. weird
    super jumbe's Avatar
    Livingstone
    Your Virgin file
  5. The Following 4 Users Say Thank You to super jumbe For This Useful Post:
    ecufix (24th May, 2013), gwee (22nd May, 2013), hesham10 (15th April, 2019), toximatic (22nd May, 2013)
    GB
    Quote Originally Posted by super jumbe View Post
    Your Virgin file
    Thank you bro for the file. Everytime i try writing the file with beeprog it fails.the eeprom is RH56 . I trief 93c56 c66 s56 s66 lc56 lc66 with no success. Any ideas? I guess Im choosing wrong eeprom
    Thankful
    marco70's Avatar
    May 2012
    Lawok
    Rohm
    Type: BR93H56-W search h56
    cjawahir's Avatar
    T&T
    hello friend , that car is later model corolla with 4 d key , i hope you did not damage the dump in the ecu , because this one you have an immo box , you need to read that and post data .
    that ecu is in the engine compartment right ?
    cj
    keygargoil's Avatar
    rh56 id fsirchild 93c56 you wont write it under anything else if you are using x prog have you read a fiole from it yet
  10. #9
    cjawahir's Avatar
    T&T
    that vehicle is 4d system with immo box , i am sure because of the ecu part number .
    cj
  11. #10
    GB
    Quote Originally Posted by cjawahir View Post
    cj
    Yes bro I will post file from immobox 2moro to reprogram keys
  12. #11
    GB
    did not try anything .. sent car to dealer
  13. #12
    gwee's Avatar
    Dec 2012
    unknown
    Quote Originally Posted by keygargoil View Post
    To write rh56, need to disconnect pin 6 and 7 under 93c56.
