Results 1 to 9 of 9
Thread: Mitsubishi L200 diesel"4d56" not star, hlep please
    electrones's Avatar
    Feb 2012
    Around C.V
    507
    Default Mitsubishi L200 diesel"4d56" not star, hlep please
    Hi friends
    I have one M.L200 2007/08 2.5l, diesel"4d56" DTC :U1101 and engine not start.
    Someone have ideia what is U1101, how to solve this ??
    In the survey i found:
    U1101 AT - Ecu communication error, AT-Ecu not present.
    But, ECU is present is connected.
    U1101 T / M, CAN time out / not fitted
    Suggestions please,
    Thanks in advancve.
    Press "THANKS" button. just one click, CHEERS
    genius76's Avatar
    Dec 2012
    Lowestoft
    316
    its always here if u hawed manual tr.
    check fuel system filters, in tank inlet filtr. air/water in system clean outlet solenoid on pump and etc.
    check if injects gets signal
    I can help you but only if you want me to help you
    All the questions should start from what car, what year, what engine is what fuel. What are the symptoms of the problem. Only then is what you know, what fault code, live data, what you have done.
    chakahafed's Avatar
    nouakchott
    DTC :U1101
    ALLWAYS IN ENGINE ECU
    DK Veteran ACDC's Avatar
    Feb 2011
    186
    Most cars can start up without their A/T ECUs....have you checked fuses? If there's no communication between ECUs that might be because there's no power supply...at least that's the first thing I'd check if I were you.
    BTW.: might be a stupid question but is the engine cranking at all?
    electrones's Avatar
    Feb 2012
    Around C.V
    507
    Hi friends
    Yes the engine turns ordinary but, have lack combustion. I will take all suggestions into account and recheck all components suggested.
    electrones's Avatar
    Feb 2012
    Around C.V
    507
    Hi friends
    Today checked all connections, fuses, relays, feeding system are ok, but When checking the sign of injectors found "759 to 845mv" no have the sign for injectors.
    I called the diagnosis "autcom" came:
    U1190 - No reception failure detection signal
    U1101-T / M, while the CAN exhausted / not fitted
    I cleared the errors and left:
    U1190 - No signal reception failure detection "
    Somene can help me to have electric scheme for verification.
    Thank in advance
    genius76's Avatar
    Dec 2012
    Lowestoft
    316
    Confused but found this
    Code No.U1190: ETACS signal receiving error
    Sorry for inferior
    Maybe Phelps
  8. The Following User Says Thank You to genius76 For This Useful Post:
    mexanico1971 (27th May, 2013)
    electrones's Avatar
    Feb 2012
    Around C.V
    507
    Hi friends
    Solved the was right, even with the error "U1101" the engine starts without problems but the issue is that the electro-injectors were arrested. After 3 attempts to smell gasoline only then started the engine after the start of the electro-ijectores the car now starts normally.
    DTC :U1190-came because of 2 fixed the fuse box were poorly fitted after correcting the error disappeared.
    Also noticed these electro-injectors work with lower voltages "789mv to 2 vol " saved error.
    I would like to thank the collaboration of all
    Thankss
  10. #9
    Sep 2019
    Hi ive got the exact same problem now, can you explain what you mean by the injectors were arrested, how exactly did you fix the fault. im on the verge of removing the injection pump to carry out internal inspection.
    My engine cranks just as you have described but no hi pressure fuel going to injectors.
