What do I do my end? Will you upload new channel list if there a problem I have a vu duo running vix thanks.
Sorry yeah all watch channels not working.
Maybe you'll have to check your own box and transponder settings, maybe an LNB switching fault? what I can say is all 3 Watch channels are working today.
(I've a similar problem with one music channel, the fault looks to be with the C/S server CLINE, because as soon as I swap out the cline with an alternative it works straight away, maybe that might be worth looking at?)
UPDATE: 18/06/2013 - (SKY UK (28.2E) ENiGMA2 Bouquets And Picons)
Updated channel scan, 94 additional new and updated Picons added since last update.
PICONS UPDATED:
All BBC One regional new and updated (SD)
All BBC Two regional new and updated (SD)
All Sky Movies both HD & SD channels new and updated
All MTV both HD & SD channels new and updated.
ALL ITV HD channels new and updated.
Plus 39 other individual Picons new and updated (SD/HD)
Channel listings and bouquets are positioned and in keeping with the current Sky HD layout.
(Edit Your Own BBC & ITV Region Channels In Dreamboxedit)
MEDLOCK - "Sgt BrickTop"
Top work mate
Thanks Sgt's it's an honour!
However I haven't set out to steal your crown, it's just that needs must and seeing as I couldn't find anything that came close to your exceptional work, decided I'd have to have a go myself, what I did seemed to work OK for me, so decided to share what I'd done, thinking it might be of some help to others who were in the same situation as I was?
It's been a very time consuming learning curve over the last few weeks, not totally alien to me but none the less very time consuming, Just need to get to the stage of just being able to maintain it, which will happen over the next few weeks / months. I accept it's not quite in your league but I do my best.
So anytime you want to take it back Sgt it's all yours?
Hope life's treating you well?
The pretender to the crown.....................MEDLOCK
mezzyg (20th June, 2013)
You are bang on with it being hard work m8. Once you get it to maintenance only I'm sure you'll find another project. I've had my 4 lists at maintenance only for about a year now so tackled 4 and 5 Sat multi list, about 5500 services I've only done 1 update on the multi sat and already I'm glad when it's just my 28.2 lasts that need updating.
Keep up the good work m8. I like to see people who are prepared to learn and contribute for the good of others.
Glad someone has taken it over it is a very hard job and chuffed to see someone dedicated to keep updates coming, I haven't done an update since February and since I seen your post I started updating a list and I'm still at it now nearly 4? hours, Hope folk appreciate the work that you do and are rewarded in your efforts
Keep it up mate
Brilliant really do appreciate this, really missed the sarge bouquets.
One thing I'm from Northern Ireland & cant find UTV in the main channel list.
No worries,
For whatever reason I don't seem to get some of the default Ireland TV channels during a channel scan, maybe because I don't have access to SKY Ireland services? Anyhow I've checked out the UTV channel and its working OK, I'll put an "Irish Variations" bouquet with most of the Irish variations channels in I can find.
So leave it with me and I'll sort it.
Medlock if you are stuck for anything give me a shout by pm if you want. I'll be happy to help you out m8.
If you manual scan it will bring up all services, AutoBouquets scan will only bring up services from your region
if you turn "Use Internal NIT Scan" option off in AutoBouquets, it will automaticaly run a manual service scan for you instead of using the data from the Network Information Table. this will then fill the lamedb with all services including none selected region and freesat services.
happy_highlander (21st June, 2013)
