Hello
I have module from ford focus 2003.
Module no is 2M5T-14B056-BD
It has a HC912D60. Pictures attached.
Could someone please help me with pinouts for reading onboard.
Thankyou.
Hello
Thankyou.
Post Pict of Connectors ! what tool u using ?
SDO (31st May, 2013)
I can use smelecom DATASMART or enigma , they all wires, I think I need rst, bkgd, gnd and +12 v, but not sure if I need an oscillator to read or no. Being extra cautious with this one cuz they die easy
Try this one, is from xprog documentation. To be sure post the mask of the MCU. Depending of the mask you will need to use security bytes to read it. If you read all AD AD AD security bytes are wrong.
Focus driver of the blue? Sticker on the HC12
18.23 GND
24 +12 v
15 COMMUNICATION
14 Control lamp
connect like this![]()
goodyou600 (28th November, 2021)
helloo there! do you know if there?s onboard programming pin connection guide for upa programmers?
Best regards!
Can you post a photo of the back side of the module circuit board. And we show that this module has security on the chip and it may not be programmable.
