Results 1 to 15 of 16
Thread: Proton Savvy
    curtpza's Avatar
    Apr 2012
    Default Proton Savvy
    Could someone please add the following key, read with AD900
    7E 4D 58 DE 50 00 00 00 00 E8 AB 7E 00 00
    eep: b2 1a 7b 0a
    curtpza's Avatar
    Apr 2012
    Anybody please
    Fallen's Avatar
    Manual procedure to enroll new key.
    curtpza's Avatar
    Apr 2012
    Fallen, there is no existing key...or rather the customer has broken the key casing and lost the transponder. The remote is also no longer working. I know the manual procedure to register the remote but it's not working. At the stage when i press the lock button on the remote, i can here the beep sound from vehicle which means it's registering the remote but the remotes doesn't work. I'm not sure if the procedure only works with a valid transponder.
    Anyway at this stage i just need to get a valid key programmed. If a key cannot be programmed in then perhaps you could generate a the 4C logic for me.
    Thanks for you reply
    Fallen's Avatar
    No, to enrol a new transponder is manual method.
    curtpza's Avatar
    Apr 2012
    Quote Originally Posted by Fallen View Post
    Would you care to share this method please
    Fallen's Avatar
    Is there a big 5 digit number written on the immo box?
    curtpza's Avatar
    Apr 2012
    I only have the immo box with me now and there is no 5 digit number but I do recall seeing it somewhere perhaps its on the outer cover...but I did see it there somewhere
    Fallen's Avatar
    Yes, it should be on the outer cover and its the override code.
    Using this code you can start the car, add a key or delete a key.
    The override procedure is as follows.
    Turn the ignition on and the immo light will go solid.
    Turn the ignition off and let the immo light flash 5 times (first #) then turn key on.
    Turn the ignition off and let the immo light flash 6 times (first #) then turn key on.
    Turn the ignition off and let the immo light flash 7 times (first #) then turn key on.
    Turn the ignition off and let the immo light flash 8 times (first #) then turn key on.
    Immo light will now flash rapidly and you can start the car.
    If you wish to program a key, add 11 to the end of your pin 5678611.
    If you want to delete a key, add 55 to the end of your pin 5875011.
  10. The Following 2 Users Say Thank You to Fallen For This Useful Post:
    curtpza (10th June, 2013), foxdata (17th February, 2021)
  11. #10
    Apr 2011
    try this and report
  12. The Following User Says Thank You to mcgywer For This Useful Post:
  13. #11
    curtpza's Avatar
    Apr 2012
    Thanks guys. I managed to get the sequence from the workshop manual. It's the same as yours Fallen. Gonna read eeprom to check how the data is entered. That should confirm your file mcgywer.
  14. #12
    curtpza's Avatar
    Apr 2012
    Quote Originally Posted by mcgywer View Post
    try this and report
    My file is slightly different
  15. The Following User Says Thank You to curtpza For This Useful Post:
    AUS-MAN (13th June, 2013)
  16. #13
    Here you are mate sorry for delay
  17. #14
    curtpza's Avatar
    Apr 2012
    Quote Originally Posted by pianoman58 View Post
    Already sorted Mr pianoman but thanks all the same.
  18. #15
    Australia
    Thanks curtpza.
    Will add this to the notes. Always like to have another method.
