Hallo friends
I have a problem.
My colleague and friend in car'repair filed, have a fault with Fiesta 1.4 Tdci.
After injector rebuild the car won't start.
A P0606 error come on and the ecu can't drive the injector, the starter work but engine wont' fire up.
So He tried to search a used ecu from local scrapyard.
After sourcing the ecu , another guy with ecu expertise, swap the 93C56 and 29F400 from old ecu to used ecu, but
a lock light come on in the dashboard and the starter doesn't work.
So he ask me to help and after i've heard the whole story I tried with my IDS and AVDI to do a reset of ecu and key learning.
But the keylearning procedure fail with error.
I've tried several option with no joy.
In the ECU memory there are a couple of error, like no key memorised or data mismatch error.
I haven't do the initial work of eprom and flash swap, so i can't assure you if the work was done
properly.
Ninja123 try to help me and i'm very grateful to him.Many thanks.
He suggest me to rewrite also the dashboard, with a the file taken from the same dashboard of car' donor ecu.
Unfourtunately there is only the ecu.
Someone have a complete set of file of similar Fiesta?
I mean dump from Dashboard,Ecu eprom and Flasheprom.
The Fiesta is a 2003 1.4Tdci with SID 802 ecu. Number: 2S6A-12A650-BG 5WS40027G-T
Which tool i have to use to write via OBD the file in Engine ECU?
Which immobilizer data are memorized in 29F400 flash?
I ask you because i have read that someone can reset rollingcode in ecu.
I kindly ask to DK ecu expert some advice and help.
Greetings
