I need help to calculate this cluster.
2012 Dodge Ram 1500 a/t gas
Original has:24571 MILES / 39544km
New desired:6,586 MILES
ATMEL 24c16
ATMEL 24c16
here 6586 miles
~6580ml....
6580ml.zip
2012 DODGE RAM-24C16-6586MLS.rar
Try this.
"A blind man leading a blind man" for the above posts
Here are all the info you need.
Your dump @24571mi / 26.688 = 920 convert to hex = 03 98 = swap = 98 03 ( see line 267)
needed 6586mi / 26.688 = 246 convert to hex = 00 F6 = swap = F6 00
now edit in running order starting from line 217 to 285
Hours is on Safety's dump.
you see B0 03?
now swap & convert to unsigned = 944 hours
now depend what hours you need then after calculation edit in running order as in
safety's dump
claudio35 (30th June, 2013)
Thanks a lot Mr. BENDER... !!! this is the kind of help that lead users to improve their skills. Besides that the mileage was already sorted out thanks to the help given by my friend AFITIJUANA, I was struggling with the hours calculation / dump location.
So to clarify about the proper way to correct hours... The location as you said @ 20D shows B0 03 =944hs So the incremental /decremental should be starting at 201 to 211 ?
So.. for 161 Hs, correct me if I'm wrong..
ACTUAL 944hs: AD03 AE03 AF03 B003 B103
NEW 161 Hs: 9E00 9F00 A000 A100 A200
Thanks!
UPDATE: I did it as stated above with perfect results.!
hahhh feal good isn't it ?
Hmm..AvechuchoAxel If i remember you are master of airbags etc..
I have same vehicle it has 20k miles and need it to be 38100 miles
I would appreciate any help
I have read Bender's post..... Im trying to see which lines i need to change ??
forgive my ignorance .....but my file has lines 210 than 220? where does 217 start?
anyone can do this for me please?
REALLY NEED HELP!!!! PL:EEAAASEE
ANYONE? please
Great post thanks everyone for sharing.
Sent from my SM-N900P using Tapatalk
Wow, I just read my posts and can't believe how much I've learned.... Thanks DK!!!!!
