As many Mazda RX8 the electric power steering failed.
What I'm looking for is some info about control module repair procedures or tips.
Everything was double checked, wiring harness tested for continuity, Torque sensor pins A B C shows 15 ohms normal resistance (AB CB), Fuse 60A is ok, Electric motor itself tested supplying straight current switching polarity for few seconds to make wheels move from left to right, CAN L - CAN H shows 1.3 / 1.5 volts, all grounds are ok.
So no power coming out of the ECU.
Diagnostic only shows the lapidary B1243 DTC CODE
Module info: F151-67880 00
J601+221587 3C21
J6 F151+67880
XJ60X-YEO-03
SHOWA ELESYS
