Results 1 to 3 of 3
    grce
    Default AUTOCOM CDP BT UPDATE
    Hellow DK friends!!!
    ...two questions please...
    -I try to connect with new S/W version "autocom cdp+ 2013.1"(delphi)...but not working....
    the same happens to 2012.3 version
    Is any case to connect???
    -In 2011.3 working fine...BUT i can't transfer the S/W to another computer
    A DK friend give me the "file activation" ....when i try to install to another p/c with the same "file activation" the program stops
    ...What can i do for these???
    thank you
    Dec 2012
    Quote Originally Posted by johnnts200 View Post
    thank you
    first your vci is a cdp pro product id >> a-710-479 for delphi it's ds150 not new vci
    can't use the same xml on other laptops just dont work
    get yourself revo uninstaller remove everything autocom/delphi
    also select windows start button in the search box type %appdata% select roaming delete autocom / delphi diagnostics folders
    again select windows start buttom type CMD when command and prompt window opens type certmgr.msc select personal certificates delete Autocom
    next you want to go to local disk C:\Windows\System32\drivers\etc\ select host.file open in note pad as admin
    edit adding the following
    127.0.0.1 activation.autocom.se
    127.0.0.1 activation2.autocom.se
    then save
  3. The Following User Says Thank You to gazvts For This Useful Post:
    johnnts200 (25th July, 2013)
    grce
    Thank you friend....you 're OK.!!!!
    Just follow your orders and solve the problem....(just use delphi with "ds150"..)
    BEST regards ....be o.k.!!!!
  5. The Following User Says Thank You to johnnts200 For This Useful Post:
    gazvts (25th July, 2013)
