Results 1 to 7 of 7
    soxten's Avatar
    Mar 2013
    Default Chrysler Voyager 2,4i 2004 ECU, Immo location/how to read?
    I have a broken ECU on Chrysler Voyager 2,4i 2004 and need to change to a used one.
    Is immo in Eeprom or MCU?
    please look at my piture and mark the chip
    ECU info
    p/n P04748376AD
    check the back of ecu fine 8-pins ic 95080 read it it contain vin edit the car vin and write back. the new ecu will start your car.
    soxten's Avatar
    Mar 2013
    Thx!
    Is it no immo in ECU?
    Do system only check so it is correct vin in ecu?
    soxten's Avatar
    Mar 2013
    I have look at the backside of the motherboard but can`t find 95080
    I have 2 Eprom
    36077AA 9322L
    8613AA 3C2D9 H347
    Oct 2013
    soxten, did you ever find out which one is eeprom?
    soxten's Avatar
    Mar 2013
    Read as 95040 Eeprom
    If car has automatic gearbox you have one Eeprom on both side.
    If i remeber correct Eeprom is fitted in one of the corners of the pcb easy to desolder the one on upper side/top.
    The Eeprom on underside/lower side is funny remove the gel and lift up pcb
    Christian Johansson via Iphone 5s
  7. The Following 2 Users Say Thank You to soxten For This Useful Post:
    bhpmotorsport (5th July, 2018), Yhoni (2nd April, 2025)
    Lithuania
    I solved the similar problem with 3.3 engine, 36077AA= M95080 eprom and have 2 locations in both sides, and both have immo data ( VIN )
  9. The Following 3 Users Say Thank You to Min2xx For This Useful Post:
    alclot (28th July, 2017), soxten (17th March, 2017), Yhoni (2nd April, 2025)
