Results 1 to 11 of 11
    Mar 2011
    Default Dreambox / Sunray
    Hi folks. Have a problem with this , getting a lock in settings from my dish . But after I upload bouquets etc. getting tuner config message. When I go back into settings lock is lost . So after I get a lock again , same thing happens. Tried few different images , same prob.....
    any help appreciated
    regards
    V.I.P. Member andy91's Avatar
    Aug 2010
    East Midlands
    Are you using Usals or Non Usals? Is Lat and Long definitely right for where you live? Andy
    Mar 2011
    Andy cheers for the reply, tbh . It's a fixed dish , and usuals is off . Any other stb I've sorted it's been simple case off uploading bouquets and set sat, and bobs ur uncle sorted...
    Aug 2010
    East Midlands
    Have you actually been into tuner configuration and set the tuner up? Doesn't matter with a fixed dish what long or lat you have in but the tuner must be configured. Easiest way is simple, positioner. Andy
    Mar 2011
    Yes bud turner set, bud when I get a lock , leave that menu . Hit say bbc 1 , I get a turner config message. ,go back into that menu , and the lock has dropped off
    Aug 2010
    East Midlands
    Could be a couple of things, are you saving the settings? Don't you have to select 28.2 on these boxes? Nit got one myself only the hd. Try a fresh set of bouquets? See if the tuner has came unseated? Try a new power supply? Andy.
    Aug 2010
    East Midlands
    Have you gone into menu/setup/service searching/tuner configuration? Andy. Check thumbnail picture enclosed
    Last edited by andy91; 5th August, 2013 at 10:20 AM. Reason: Added picture and info
    Mar 2011
    Yes matey I have done that. Will try different bouquets, and get back to ya. Am just while ur here . I have an original 500 hd, best place to buy an drive for recording and multi epg, there's only an e sata on the back ...
    regards
    Aug 2010
    East Midlands
    China is cheapest if you were to buy another box and ship them together, Andy. h**p://www.mixeshop.com/brand-new-sata-hdd-25inch-250gb320gb500gb640gb750gb-for-dm-box_p2569.html
    Mar 2009
    when you go into the menu as andy says change positoner to disceq and select 28.2 save and you should be good to go
    Mar 2011
    ok thx very much
