Results 1 to 15 of 15
    Mar 2009
    Default Vauxhaul corsa D 2008my 1.4 z14xep unstable idle and switching off
    Hello
    I am working on this Corsa D 1.4 with Z14XEP engine. The problem is the vehicle has an unstable idle and switches off when coming to a stop.I have attached the fault codes and live values from OPCOM. I have 5 fault codes. I can clear them. I have viewed the map sensor actual values and it seems to be operating correctly. The oxygen sensor voltage seems to be rich all the time please view the attached logs.
    Identifier: 0x0A35
    VIN: W0L0SDL6884268395
    Hardware number:61208941
    Motor type: Z14XEP
    Part Number:55557934
    Software version number: 42070501
    Hardware manufacturer number: 0261208941
    Programming Date: 20080109
    Hardware key number: 19NX7669
    System description: BOSCH0100
    Type approval number: B07003
    Variant programming : 0x20202020202020202020202020202020
    Alpha code: AY
    Manufacturing date: 20080109
    Hardware manufacturer system name: ME7.6.2
    Code Index and version: 1037381911
    Total number of fault codes: 5
    P0172 - Fuel Trim Malfunction (Bank 1)
    (00) - Not present
    P1138 - O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
    (00) - Not present
    P0068 - Manifold Absolute Pressure Sensor Circuit Range/Performance
    (00) - Not present
    P0131 - O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
    (00) - Not present
    P0134 - O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1)
    (00) - Not present
    Mar 2009
    another thing, in live values under manifold pressure ,the voltage fluctuates when the accelerator is depressed but the kPA value stays at 101kPA seems rather strange
    Meat-Head's Avatar
    Right, might be wrong, but worth a look, assuming you use rain in your country?
    Lift up the under hood fuse box, look and unbolt the multiplugs, see if rotten as a peach, ?40 + VAT Inglish pounds 1 foot of loom from ECU to fusebox
  4. The Following User Says Thank You to Meat-Head For This Useful Post:
    bonecrusher (6th August, 2013)
    Mar 2009
    will check and report tomorrow
    Aug 2011
    uk
    open up oil filler cap while engine running and see if its hard to take off as if of vacum, if it is you need to clean rocker cover breather or replace, this fault causes symptoms like yours
  7. The Following User Says Thank You to flyins For This Useful Post:
  8. #6
    Meat-Head's Avatar
    Quote Originally Posted by flyins View Post
    Not going to argue, but the same rumor is a bit longer, also states the oil pressure switch starts leaking, due to excess pressure, again something to do with the breathers, but somehow rumor got mixed up.
  9. #7
    Mar 2009
    Meaty,
    Once again you are 100% correct, rotten as a peach.
  10. #8
    Meat-Head's Avatar
    5 or 6 plugs on the loom, what was the cost of part?
    I didn't get where i am today by fixing other peoples cars from thousands of miles away.
  11. #9
    Mar 2009
    About 120 quid in my part of the world. If cust approves repair three days for loom to get to me. Just out of curiosity how much will you charge out for a job like this
  12. #10
    Meat-Head's Avatar
    Quote Originally Posted by bonecrusher View Post
    Well the one and only one of these we at at M-H-M on face value was 100% ECU - but we make it clear we needed to check the wirng to be 100%
    It went to a member of an INFERIOR forum, who diagnosed the loom
    We charged i think 1 hour labour
    Next one i guess as know about it 1 or 2 hours labour + parts + VAT
    When you say "?" thought you was with Toto in Africa?
    Whereevr you are you must use rain like we do otherwise wount have been rotten
  13. #11
    Netherlands
    I had an Astra 1.4 2 weeks ago same issue leaking oil pressure sensor. Stealers would charge 2700euro to cust for new loom, ecu, oil sensor, 2 lambda sensors.
    I put new loom on it (560euro over here) ,oil pressure sensor, 2 aftermarket bosch lambda sensors and clean the ecu.
    With labor almost 1000euro.
  14. The Following User Says Thank You to easytech For This Useful Post:
    bonecrusher (9th August, 2013)
  15. #12
    Meat-Head's Avatar
    easytech what was the problen, did it really need all that work?
  16. #13
    super jumbe's Avatar
    Livingstone
    In your report you have fault code manifold absolute pressure sensor its worth checking that your EGR valve if it stays slightly open the engine will not idle.
  17. The Following User Says Thank You to super jumbe For This Useful Post:
    bonecrusher (8th August, 2013)
  18. #14
    Netherlands
    Manifold pressure sensor is also a possibility indeed.
    In my case the loom was completely soaked with oil and of course the oil goes to the lowest points, lambda's and the ecu.
    I took the old loom apart strange enough the oil is not under the isolation tape and wire but in the wires itself so only thing left is to replace the loom.
    The lambda wire's are also soaked and so is the iridium or platinum piece inside not working anymore.
    Same shit happens with Peugeot or Citro?n with the watertemp sensor but then with coolant of course, loom, ecu and most of the connectors are gone.
  19. The Following User Says Thank You to easytech For This Useful Post:
  20. #15
    Jun 2015
    hi
    z14xep corsa d 55557934
    carprog
    eprom I need it
